Question about Jenn-Air JED8430 Electric Cooktop
One burner no longer adjusts temp when moved from 1 to High
    President:
  • 1,430 Answers
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Posted on Oct 02, 2010
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
234 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
