Question about Kodak Cameras
When I turn on my camera I get a msg saying " Memory Card is protected (Reset switch on memory card)" Ummm what!!! I can't get this msg to go away, and now I cant take pictures. At the bottom of the screen it tells you to "go to review", when I do this I can find nothing that will help. Help!!!
  • 3,866 Answers
Most SD cards have a little plastic switch, However if you using a SD adapter it might not be fully reading the adapter witch causes this error or the camera is defective.
So if at one point things where hunky Dory and now its saying this try another memory card and if that does not work then the camera is the issue.
Posted on Oct 02, 2010
  • quesadars Oct 02, 2010
    Thank you!!! I have been going crazy trying to figure this out. Your solution seems to have worked for now!!!
  • Grand Canyon Tech
    Grand Canyon Tech Oct 02, 2010
    please leave a rating and feedback if you would, Thanks
How did my memory card get protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 29, 2014 | Kodak Easyshare CD82 Digital Camera
Is there a way to fix my memory card when it says cannot create folder?
The memory card may have the write protect switch on.
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 13, 2013 | Canon EOS 40D Digital Camera
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. what i do?pls explain with pictures
If the memory card is a SD memory card then
Feb 22, 2013 | Sony Cybershot DSCW310 Digital Camera
Sign comes up when screen turned on to say memory card is protected and wont go away. while this sign is on camera cant be used
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 12, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
My screen says memory card is protected (reset switch on memory card)
Just turn off the camera and take out the memory card. Then just adjust the small tab located at the upper left side of the card to unprotect it. Then put back he card and turn on ye camera again. That's it!
Jun 27, 2011 | Cameras
Can't get my camera off interal memory have new sd card?
my camera says memory card protected when i turn it on. it says to reset switch on memory card, but then when you put it back in the camera, it switches back. it wont let me do anything with it.
Oct 23, 2010 | Kodak Easyshare CD82 Digital Camera
When camera is turned on it says memory card is
If you're using an SD card, it doesn't have a reset switch. It does have a switch to lock (protect) and unlock the card. It should be in the unlocked position.
Jul 21, 2010 | Kodak Easyshare C813 Digital Camera
It says my memory card is protected
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card form your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
Apr 09, 2010 | Kodak EasyShare One Digital Camera
How do i turn off the memory card protect
There's a sliding switch along one edge of the card. Move it away from the contacts.
Dec 18, 2009 | Nikon Coolpix S210 Digital Camera
Screen is saying Memory card is protected (reset switch on memory card) and it won't take pictures.
if you have tried to set the switch to unlocke on your SD card, and still have this problem, you may need to open your camera to check the SD card slot.
this tips might help:
http://www.myfixtips.com/blog/uncategorized/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
May 07, 2009 | Kodak EasyShare M1033 - black Digital...
Cameras Logo
81 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
