Photosmart d5160 keeps telling me "cover is open" - i cant find any cover open
  • 2 more comments
  • guydenning Jun 27, 2008
    Just bought and installed a new HP Photosmart D5160, had to download the driver as the disc provided didn't have Vista drivers. I've tried restarting the PC (Vaio laptop) and restarting the printer but just keep getting "cover is open" message. I'm not impressed.
  • Anonymous Oct 10, 2008
    Me too! It's driving me mad!
  • Anonymous Dec 09, 2008
    e open
  • lyricalmirac Jan 15, 2009
    same problem here
I have had this issue with two D5160's, a poor cheap design i in my opinion. Symptom's were that after you had lifted and then lowered the main lid the red exclamation LED would continue to flash. The left hand front corner of the lid (near LED) did appear to be raised up but pressing it down made no difference. Sometimes if you listed the lid a couple of inches and then let it drop everything would be OK.
With the power cable disconnected I removed the left hand side off the printer, this is just clipped on but you do have to be careful with the part that wraps around under the card reader. This needs to be bent quite a lot to remove but it is possible without breaking. Start at the bottom gradually pressing the clips and separating it from the printer. Gradually work around up the front and then it lifts away from the top of the printer. Now, if you raise and lower the lid you will see two sliders moving. These are the problem, they tend to bind and not allow the mechanism to slide enough. I applied a small amount of silicone lubricant spray to each slider. After a couple of operations the difference was really obvious, the lid now does all the way down so its sits flush. Clip the side back on by reversing the above procedure and your done. Hope this helps.
Posted on Jun 16, 2008
Hello David.
This is a recurring problem with some of these printers. It can be caused by a sluggish cover reset switch.
The remedy is to lift the cover to around 30mm and let it drop down. this should reset the switch and remove the red ! mark from the LCD window..
Arnie.
Posted on Jun 15, 2008
I cant believe it, the 30mm drop (top cover) worked !
Posted on May 28, 2009
The problem is with the plastic mechanism in the door switch. You pull off the end cover to expose the mechanism & lift the switch manualy and then glue in a small piece of plastic to keep the lift bar straight as I did on mine.
Posted on Feb 18, 2009
30 mm drop worked !! After I had 'retired' the printer and replaced it with a Canon in frustration ! Pity, I now just love the Canon.
Posted on Sep 04, 2009
Arnie.
Hi: Re HP Photosmart D5160 printer: 1) Prints a
You may have added a separator page,
1). Open printers and Faxed.
2). Right-click your printer and select 'Properties'.
3). Click 'Advanced' tab
4). click 'Separator Page'
Delete any text in the box and click 'OK'
Sep 13, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 gives error message -0 03 31 IF F$ 4d dd d6
Issue
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Mar 05, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160. Software won't install on computer with Windows Vista
u must uninstall software unplug your HP!
Shutdown your PC!
Reinstall drivers!
Connect your HP D5160 printer
Sep 21, 2010 | HP Photosmart D5160 InkJet Printer
Help, I have lost my installation disk for my HP Photosmart D5160 Printer. They would like to charge me $38.00 for a new disk. Any suggestions?? Thanks, Mary
You can download the Softwares/Drivers for your printer from these links (similar with the contents on the Hp CD) :
Hp Photosmart D5160 Printer for windows xp 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL15834/dj-41864-2/TF_regna_psp_NB.exe
Hp Photosmart D5160 Printer for windows xp 64 bit
or
Hp Photosmart D5160 Printer for windows vista 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL18384/dj-47558-2/SF_CDA_Full_Non-Network_enu_NB.exe
Hp Photosmart D5160 Printer for windows vista 64
or
Hp Photosmart D5160 Printer for Windows 7 32 bit
or
ftp://ftp.hp.com/pub/softlib/software11/COL30907/dj-76773-1/SF_CDA_NonNet_Full_Win_WW_130_140.exe
Hp Photosmart D5160 Printer for Windows 7 64 bit
or
Hp Photosmart D5160 Printer for Linux
For Mac Drivers, please visit here and follow the instructions given there.
It would be much easier for you and for me if you had mentioned the Operating System installed on your computer where you are going to install the printer. Anyway, select the suitable link for your operating system.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP Photosmart D5160 InkJet Printer
Photosmart d5160 keeps printing a test page after i print anything
Please perform the following steps:
* Make sure the CD/DVD tray is closed.
* Double-click the HP Solution Center icon.
* In the HP Solution Center (for Windows OS, if you are using Mac please let me know), click the tab for the HP Photosmart 5100 series.
* Click the Settings button.
* Point to Print Settings.
* Highlight and click Printer Toolbox.
* After the Printer Toolbox opens, click the Align print cartridges button.
* Follow the on-screen prompts to align the cartridges and print an alignment page.
:) Dr Tony
Apr 17, 2010 | HP Photosmart D5160 InkJet Printer
Problem of my printer photosmart d5160
I have the exact same printer. Struggled for hours with it, until I learned it's ways. If you have good cartridges in and purge your print buffer from your computer, then 'gently but firmly' slam the top cover.
I don't see sensors, etc that detect it being up, but I just closed mine, had ! blinking, etc. Then gently 'slammed' the top cover and it reset and worked great.
Apr 24, 2009 | HP Photosmart D5160 InkJet Printer
Cannot remember how to load new print cartridge on to my HP Photosmart D5160 series printer
keep the printer ON.then open the flap on the front side.there is a small gap made in the flap to get it opened.as u open the flap the cartridges will automatically move and come in the position where u can remove the cartridges.just pull the cartridge to the dwn side near to you and it will come out.in the same way insert the new cartridge.
Nov 30, 2008 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160
Hi Arnie,
Infact the machine cover is not a customer replacable part, hence u ll not be able to open it . however if u try to open it make sure u ll not break the bezel.
thanx .. nd best of luck
Jun 15, 2008 | HP Officejet 5610 All-In-One InkJet...
772 people viewed this question
k24674
jasbo
jasbo
