Question about Whirlpool Dryers
Screeching noise when the dryer drum is rotating. Whirlpool LER7 model. Is there a bushing or bearing I should locate
  • 10,319 Answers
The drums belt is turned by a belt. this belt runs around a idler pulley. the pulleys bearing is bad causing this noise
Sears sells the belt and pulley as a kit with instructions
Posted on Oct 02, 2010
Everything works but it is making a awful noise when spinning like sand and metal is grating
Sounds like drum bearings may be bad. They use make horrible almost screeching noises. You would need to look up your particular ubit. On some they are integrated into the drum as an assembly and replacement is expensive.
Oct 17, 2016 | Dryers
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Dryer making a screeching noise when rotating
There are parts inside the dryer that require periodic maintenance, such as oiling the drum wheels, replacing the drum glides - when they become worn.
Sep 25, 2012 | Hotpoint Dryers
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
My Maytag dryer has just now starting making a sqeeling noise. What could it be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 14, 2011 | Maytag Dryers
My Maytag dryer makes an awful screeching sound when I start the dryer. It still dries the clothes, but I can't stand the noise.
your rollers or belt idler is corroded. you need to take dryer appart and lubricate the parts in question with MINERAL OIL or SPECIAL BEARING LUBRICANT. """"DO NOT USE WD-40 OR 3 IN ONE OILS"""". good luck to you.
Feb 07, 2011 | Maytag Dryers
Screeching noise
rear drum bearing needs to be replaced
Sep 25, 2009 | Maytag Dryers
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
