Question about Bunn VPR Coffee Maker
How do you delime a bunn vps series coffeemaker?
SOURCE: replacement of limit thermostat on VPS Bunn coffee maker
http://www.cw-usa.com/parts-bunn-commercial-thermostat-limit.html
Posted on Jan 04, 2009
  • 131 Answers
SOURCE: difficulty in inserting the plastic deliming tool in bunn coffee
try keeping pressure on it, and turn it around as you insert it. You are trying to go around a corner in the tubr, and sometimes it is hard to get it to go around the bend.
Posted on Feb 10, 2009
  • 131 Answers
SOURCE: empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
Posted on Feb 11, 2009
  • 125 Answers
SOURCE: Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
Posted on Mar 23, 2009
  • 125 Answers
SOURCE: How do you drain all the water from the resavoir
Hello. Take the funnel out, under it is the spray head, remove it, unplug the unit, take it over to a sink and tilt the end that the spray head was on into the sink slowly, the water in the tank will drain out through the spray head pipe until mostly empty. You also could take the top off, take the tank lid off, and use a shop vac to vacuum all the water off, or just pour it out, probably faster, but messier :) If you need information on you unit, go to www.bunnomatic.com , chose commercial, and then on the left, choose coffee, and pour overs.
Hope that helped, and thank you.
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
Bunn CW series slow water flow
delime the sprayhead and the reservoir drain in the top with a deliming spring or a screwdriver
Dec 03, 2012 | Bunn CWTF 15-3 Coffee Maker
Looking for an electrical schematic for a Bunn VPS
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Sep 23, 2011 | Bunn VPS Coffee Maker
Coffee comes out very slowly
Remove the sprayhead from above the filter basket (when cool) and check it for clogs. You can soak it overnight in a dish soap solution and it should be easier to clean. Rinse it well before use. You should also **** the siphon tube (just beyond the sprayhead) with the deliming spring.
Aug 04, 2010 | Bunn VPS Coffee Maker
How to drain coffeemaker
Empty the water reservoir and put back on the side of the coffee maker. Put your hand in the reservoir and slide the disc that monitors the water level back toward the top and and hold in that position,the machine will think there is water. Then put a cup under the head and select a cup. The water will come out. You must hold the disc up inside the reservoir to continue to get the water out.
Here is another tutorial : http://www.ehow.com/how_5849515_drain-reservoir-bunn-coffee-maker.html
May 30, 2010 | Bunn VPS Coffee Maker
Bunn coffeemaker starts before water completely in reservoir
You might try this first. Remove the entire top lid and remove the clear suction cup located near the back of the brewer. Clean this cup with white vinegar and also take your deliming tool and place it in the hole where the suction cup was and clean out. If this does not correct the problem, please call customer service with the model and code date. If your machine is 3 years old or less, we can replace it at no cost. If it is over 3 years old, we will replace it at a reduced price.
Oct 06, 2009 | Bunn NHB Coffee Maker
We find water under the coffeemaker in the morning.
Sounds like a leaking water pipe from the water source, unless you have a over temp heater and this results in steam and dripping.
Mar 30, 2009 | Bunn VPR Coffee Maker
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn VPR Coffee Maker Logo
339 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
