Question about OKI Computers & Internet
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation disk, the installation comes to a point where it asks if the printer is local or if it´s in är network. I anser that it is in a network. Then it asks me if the printer is conected immediately to the network. (Is conected to the printer server and the printer server is conected to a router) I anwer " direct to network with TCP/IP". Then it asks me to write the IP-adress, well I don´t know what the adress is. ( I tried tho search whith the standard broadcast 255 255 255 255 adress but it could not find the writer. The Router is configured to use DHCP. How do I find out the IP-adress?
  • OKI Master
  • 3,467 Answers
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Posted on Mar 18, 2017
  • Brett Duxbury
    Brett Duxbury Mar 18, 2017
    usb server software should have an option called have disk and then you point it to the install disk location and it should find oki driver.
5 Suggested Answers
beeveez
  • 167 Answers
SOURCE: Need to install network printer to DLink Router
- First, you have to make sure the Printer you were attempting to install is in range with the LAN IP Address of your D-Link router.
- Second, You have to run the Add a Printer Wizard.
Posted on Mar 14, 2009
  • 25 Answers
SOURCE: Can't connect to WPSM54G after configuring it
hi sir,
1. first reset the printserver
2. make sure that the printer drivers are installed on the comp.
3. use a w/l comp on which we can go online
4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
5. put the print server cd into the comp and run setup.
6. make sure printer server is near to router and there is no firewall on the comp.
7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
8. follow the wizard
9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
12. if u dont knw, u can ask the comp vendor.
13. plz also confifm that the printer is compatible with ur print server.
thanx and regards
sukhiii
Posted on Jul 26, 2009
SOURCE: Wireless-G WPS54GU2 Print Server Lost disk
I have placed a copy of the setup cd that came with the print server on one of our servers. It also has the drivers and manual. ftp://controlc.org/wps54gu2.zip
Posted on Mar 16, 2010
sweetlady105
  • 36 Answers
SOURCE: I have print server d-link
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Posted on Nov 05, 2010
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
Tip
Configuring NETGEAR print server PS121 printer port settings manually.
If you can not run the installation software for the print server PS121 on the computer then you can try the below steps to manually configure the printer port settings:
Step 1:-
1. Visit the link below to make sure that the printer is in compatibility list:
http://kbserver.NETGEAR.com/kb_web_files/n101216.asp
2. Make sure that the printer is working in direct connection with the computer.
Step 2:-
1. Now connect the printer to the USB port of the printserver and then the Ethernet cable from the router to the Printserver Ethernet port.
2. Press the DIAGNOSTIC tool button on the printserver for 10 sec (All the lights will blink amber), you will receive a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router. If there is no ip address then powercycle the router, printserver and the printer. Press the diagnostic tool button again.
Configure printer port settings on XP computer:
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Configure printer port settings on VISTA computer:
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
These steps will help manually configure the printer port settings on the computer.
on Feb 10, 2010 | NetGear PS121 Print Server
Have installed a netgear ps121v2 server. Will work with the ethernet cable connected server to router and usb server to printer but will not work without the ethernet cable. System: Vista Home Premium ...
following steps can fix your Issue
regards,
prakash
Mar 14, 2010 | NetGear DG834G Router
Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
DP301U COMPATIBILITY
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    Cannot configure the wireless USB Print Server
    first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
    May 06, 2008 | Port Incorporated Wireless 11Mbps...
    Issues Printing with DPR-1260
    This worked for me and I was having the same issues as everyone.
    http://support.dlink.com/faq/view.asp?prod_id=2705&question=DPR%2D1260+vista
    Before I put this solution in (manually adding the printer step-by-step), I could print a test page just fine, but not anything from Office.
    Make sure to follow each step in order. I printed off the test page and held it up to the old one and the only thing I saw different was a field named "Shared". It was blank but who knows. I'm just happy the darn thing is working!
    Dec 15, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
    Configure to print
    You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
    Feb 16, 2006 | D-Link DI-704UP - 4-Port Broadband Router...
    Computers & Internet Logo
    Top OKI Computers & Internet Experts
    David Payne
    David Payne
    Are you an OKI Computer and Internet Expert? Answer questions, earn points and help others
