Question about Whirlpool GBD307PR Electric Double Oven
I have a Whirlpool GBD307PRB01 Accubake oven. It is ~3 years old. Yesterday, the display went out. I've reset the breaker, but no change. When I try to start the oven, I get a beep code 1 short -1long - 3 short. Since the display is out, I don't know what the alphanumeric code is to go along with this. If the display code is telling me to replace the display, I can do that. I just don't want to replace one part to find out it is another part causing the problem
5 Suggested Answers
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
vest6
  • 196 Answers
SOURCE: Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Posted on Jan 26, 2008
oldTech2332
  • 2341 Answers
SOURCE: My whirlpool double oven accubake GBD307PDS09
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Posted on Aug 20, 2011
  • 2128 Answers
hi,if the clock went blank it has nothing to do with the sensor,it's a double oven and if you were having a problem with one of the sensors it would show a code on the oven you were trying to use,usually when the clock display doesn't work and both ovens don't work most likely i would say you have a bad computer board,you can first try shutting the breaker off for 10 to 15 minutes and then turn the power back on and see if that does anything,i've done this before,the clock came back on and the ovens worked until they heated up and then the clock went blank and the ovens shut down,the thing that was happening was there's a fan in the back that runs to keep the electrical stuff like the computer board and the wiring cooled down,her fan had all dust stuck on the screen that was in front of the fan and the fan cooked and then the computer board overheated.this isn't something someone can answer online,you have to call in a tech to check it out for you and see what the problem is,when parts cost 200 dollars or better,you need someone there that can do some checks with a meter to see what is actually bad or what caused the problem and then you know it's done right.wish i could help you out but i would suggest calling in a tech for this one.good luck
Posted on Aug 22, 2011
Whirlpool Gold Double Wall Oven will not heat
check the heating element for opening or cracks
Mar 17, 2014 | Ovens
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Whirlpool GBD307PR Electric Double Oven Logo
424 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
