Question about Toro 20360 eCycler 20Inch 36Volt Cordless Electric BaggingMulching Lawn Mower
This Toro 20360 e-cycler is a battery operated mower. It started making a grinding sound after running over some small branches. There's no material wrapped around the shaft which could be making this noise.
5 Suggested Answers
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
rycgl
  • 1545 Answers
SOURCE: My Toro Super Cycler ran fine all summer. No it
Remove the bolt that holds the bottom float bowl on the carburetor and clean it thoroughly. Careful, as it has an exterior washer between the head of the bolt and the bowl. Careful with the carb body gasket above the bowl also. The brass bolt is the main jet of the carb and if you are not using an inline fuel filter, debris, dirt, sediment and gum and varnish collect on it. There are very small holes in the bottom and along the smooth sides of the bolt. Use no metal on it at all. If you need to scrape on it, use wood or plastic.
Posted on Nov 16, 2010
Knucklebstr
  • 222 Answers
SOURCE: My parents have a self
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Posted on Sep 16, 2011
  • 25 Answers
SOURCE: toro recycler mower won't stay running
take apart the carb float and clean it out, then take apart the rest of the carb and spray cleaner through it. sounds like you might have some old gas turned to jelly in your carb thats plugging it too much for the typical pressures inside the carb to **** through
Posted on Jan 25, 2012
Toro super recycler
Push primer bulb at least 3 times. Pull starter rope until it starts. Ensure safety lever is engaged on handle.
Aug 02, 2013 | Garden
Manual for TORO ecycler
Click the link, Click the "Maunuals" tab, Click the Language you want. Your manual will download (12 Pages).
James
http://tinyurl.com/cldx3f8
Dec 13, 2011 | Toro 20360 eCycler 20Inch 36Volt Cordless...
I just purchased a Toro e-cycler cordless mower, model # 20360. I tried plugging in the charger to the Ac outlet and the mower receptacle. My understanding is that the charger light is suppossed to be...
It could be that the batterys don't need to be changed and shouldn't be unless fully discharged, if u charge before the batteries are fully discharged u run the risk of damaging the batteries. The problem is sometimes batteries get what is called a memory charge, this means if u use your lawnmower for a short time than charge it and u do this repeatedly the batteries will only discharge for this sort time and will only charge for a sort time. Than if u need it for a big job it will seem that u have only operated it for a little time and u need to plug it in. The only way to fix the batteries is buy new ones, that way they always tell u to always fully discharge before recharging your batteries.
Sep 15, 2011 | Toro Garden
My Toro Super Cycler ran fine all summer. No it starts and then stops immediately.
Nov 16, 2010 | Toro Super Recycler Super Bagger Lawn...
I have to put oil in my brand new mower everytime I mow
I would DEFINITELY take it back where you got it! This is NOT a good thing. It sounds like it's about to seize up on you. Don't use it any more and take it back.
Jim
Sep 23, 2010 | Toro 20360 eCycler 20Inch 36Volt Cordless...
How to start the Toro lawnmower
There may be a safety switch or procedure somewhere so check the manual for such if there is one here:
http://www.manualsonline.com/
Please vote if this helps...or even if it doesn't!
Aug 31, 2010 | Toro 20360 eCycler 20Inch 36Volt Cordless...
Toro 20360 eCycler 20Inch 36Volt Cordless Electric BaggingMulching Lawn Mower Logo
80 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
