Question about Delta Faucet DELTA/PEERLESS FAUCET CO. P99196 TWO HANDLE LAVATORY FAUCET - CHROME
How do I disconnect quick connect hose from a Delta kitchen faucet
    New Friend:
Solution 1 from Rico did work but it required the use of pliers in each hand to apply enough pressure to hold the top part in place and to pull on the bottom part down. It took several attempts but it came apart.
Posted on Jan 30, 2013
3 Suggested Answers
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
  • 10 Answers
SOURCE: my delta kitchen faucet model
Is there a little rubber O-ring that may need replacing or is missing? You might try removing and flushing out the line and replacing it.
Posted on Dec 03, 2010
Remove delta quick connect hose
pull the black plastic piece down. you should hear a click. then gently pull the hose out. no matter what , BE GENTLE. Those things do seat very well but you have to be careful on removing them. Installing is easy, just a push in until it locks.
Nov 09, 2013 | Delta 2402 Classic Single Handle Kitchen...
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
How do I secure the quick connect clamp to my main water line?
the quick connect should go to the sprayer hose and there should be two lines for the hot and cold.....??? does that help..
Jan 26, 2011 | Delta 2402 Classic Single Handle Kitchen...
My delta signature faucet is leaking from the top of the hose. I want to take the hose out to get a replacement. I have started to disassemble the faucet but don't know how to remove the cap.
i am not sure which cap you refer to. there is a cap just below the handle. turn off the water supply for safety and remove handle then turn the cap counter clockwise. to replace the hose you should only have to disconnect at the handle to the sprayer and the other end at the faucet below the sink. if you wish to remove the faucet then after shutting off the water undo the nut below holding the faucet in place. delta have a good web site where you can see a breakdown of this faucet.
Dec 29, 2010 | Delta Model 470: Signature Kitchen...
My delta kitchen faucet model 21902 quick connect spray hose leaks where it connects to the faucet. Help
Dec 03, 2010 | Plumbing
The O rings need to be replace, but you can not get the handle off because if the hose. How do you disconnect the hose so you can remove the handle.
handle should have an allen screw rite under the handle coverd by a little cap mite have red and blue..shouldnt have to take hose off but that just snaps off from under sink.
Nov 21, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Delta Faucet DELTA/PEERLESS FAUCET CO. P99196 TWO HANDLE LAVATORY FAUCET - CHROME Logo
9,686 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
