Question about Zanussi Washing Machines
Hi, I have a zanussi washer/dryer and after using the dryer I newer did before, I cant start the washing program, I am delating the program many times and re seting but I cant use the washing mashin now, what do I do wrong?Please help!!!!
  • 4 more comments
  • andipanda197 Oct 02, 2010
    Sorry but what you are saying is not making any sence we dont have that shell with some information, the masine start flowing water for a second and is stop and the start buton is flasshing,I deleted the program and start reseting, I tryd all the program and non of them working more than a seconds, how can i trouble shoting? I would be glad if I can get a helpfull answer and solution for the problem, I dont think I need any parts to be replace to be anest.
    Thanks
    Andrea
  • andipanda197 Oct 03, 2010
    Hi
    9 hours ago a send a question to guru still not get a answer.
    My problem is I have a washer/Drayer and after using the drayer I cant use the washing masin, is starting the program take some water and stop the start button flassing, is no part need to be change, he told me abou some shell, what I dont have. Can you tell me how to trouble shoot and what steps I need to do to resolve this isu, this is the second time happening, and now nothing works so far, also can I get the answer before lunch other wise is no fare me to pay for this service.
    Thanks
    Andrea
    Its a joke Im just geting the same answer what is nothing is anybody can help me out for my money ????
    how can I get a local techincian to come over asap and see the problem?I am leaving in dublin 13
    hi i see only the 1st solution out of 3 how can i see all of it?
  • andipanda197 Oct 04, 2010
    Only the start and pause buton flashing continously
  • Zanussi Master
  • 19,396 Answers
Hi Andipanda.
Sorry to hear about your problem. We have some good tech at Fixya, but also casual posters. I saw your question only today, I will try giving some minimal troubleshooting. If you want to send comments about Fixya, rather than posting here, write to premium.support@fixya.com.
Go through the following troubleshooting. If the machine is less than two years old, instead of proceeding with the operations that need disassembly, call Zanussi to find out about your warranty status. If warranty is still active you can get a technician at home. Zanussi number is listed in the use and care manual.
The current situation is a machine that starts filling and stops after seconds, the problem happened after running a dry cycle.
Step 1 reset the machine: Disconnect the power cord or trip the circuit breaker for five minutes to reset the machine. This will drain power completely and can get rid of troubles that cannot be fixed by using the hold down start/clear button procedure.
Step2 Check the thermal fuse.
Next step is checking the thermal fuse, which is this. The part is located in the heating group, and it is usually accessible from the back of the appliance on Ariston Margherita, Electrolux and similar. The thermal fuse is removed from the inside of the machine, and tested using and Ohmmeter. If the Ohmmeter reads infinity (open), the fuse must be replaced.
Since the machine failed after a dry cycle, then the thermal fuse may need replacement.
If the thermal fuse blew, then there is a problem with ventilation, a plugged element or a faulty high limit thermostat. Usually the problem is air ventilation, check it out.
3 Check inlet adn drain hose.
Move the machine forward and check inlet and drain hose. Ensure the hoses are not kinked or blocked, since the cycle stops when you start filling, then the inlet is more likely involved.
Check inlet hose.
Ensure that hoses are at the heights specified in the user manual, or you may get syphoning (see manual at start-installation).
If there is nothing at a glance, next step will be testing the inlet valve with a multimeter , checking the pressure switch, then checking the thermostats and other parts.
The thermal fuse testing is already a non-user-level operation. If you have to proceed in testing parts I suggest getting a tech at home.
Try tripping the circuit breaker, checking hoses, and dry water from the inside before restarting. If that does not work, then there is a fault. In that case call service if you have a valid warranty, or give me model number if you need more specific info on repair.
If you think this solution someway helped, please do not forget to accept the solution.
Regards.
Ginko.
Posted on Oct 03, 2010
  • 2,272 Answers
Zanussi washing machines are some common appliances that display coded error codes. basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
so i will need you to tell me the number of times the light is flashing. so we can determine exact error code and then try solving the problem the right way.
thanks.keep updated.
Posted on Oct 04, 2010
  • 10,865 Answers
Hello. Here is a free download of the manual which will take you step by step to solving your problem. http://safemanuals.com/brand-user-guide-instructions-owner-manual/ZANUSSI
J.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks!!
Posted on Oct 02, 2010
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
ZANUSSI ZWF1221W LIGHTS FLASHING UNABLE TO START PROGRAM
zanussi zwf12270
hi, my machine does not take the the fabric softener from the top tray.
this happened for about two weeks.Does anyone know the reason. thanks for your time
Apr 30, 2011 | Zanussi ZWD12270 Front Load Washer / Dryer
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
Mar 26, 2010 | Zanussi ZWF1650W Front Load Washer
Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Sep 20, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
My Zanussi zwx1605w
norm faulty heater/element iff not faulty pcb
Jul 13, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
OUR WASHER DRYER WONT WORK.
First try power off reset,.. unplug and re try
Jul 19, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
390 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
