Question about Garden
Service manual for 2005 Dixon speedztr 44 - Garden
4 Suggested Answers
  • 32 Answers
SOURCE: how do i replace a bearing on my center pulley on a dixon ztr ram 44?
if its for the blade spindle it comes as an assy. no replaceable parts
Posted on Apr 14, 2012
  • 6468 Answers
SOURCE: dixon speedztr belt is loose when I try to engage won't work
look to see if the belt is on all the pulleys and all the linkage rods are in place
Posted on Apr 21, 2012
  • 183 Answers
SOURCE: I need a diagram for the drive belt on my lawn mower. It's a Dixon SpeedZTR 44.
What are the make and model of the machine?
Posted on Apr 30, 2016
WE have a dixon husqvarna ztr mower model 966004101. It wont turn the starter over. We purchased a new battery wasnt sure if it was something to do with safety switch
Just had this problem. When you turn the key all the way over to start does it at least turn over like the battery is dead or do nothing at all? If nothing at all the solinoid is bad. Mine is a speedztr 42". Mine for 2 years was draining my battery and I had to leave trickle charge on it year round. This year when I tried to start completely dead although battery tested 12.37. Found the ignition switch was bad and replaced it and solenoid. 12.00 each at local hardware store. Starts and runs like a dream with No trickle charger! I would start with solonid if your battery is not being drained every week.
Apr 12, 2017 | Husqvarna Garden
Dixon SpeedZTR 48 SE: When I want to start the blades, I pull the big red button. Now, nothing happens when I pull the red button
Probably an interlock switch is malfunctioning. Most common is the seat switch, but there are usually two or three interlock switches involved.
And it's also possible that the "big red button" or the electric clutch is bad. There's no way to tell without trouble shooting the wiring and components.
Is there an in-line fuse on this mower?
Aug 13, 2016 | Garden
Why won't my transmission re-engage on my Dixon Speedztr 30 lawn mower?
Sounds like a broken or disconnected cable to the drive unit trace the cable run to the drive just make sure all connections are sound.
Jun 22, 2014 | Garden
I have a 2009 dixon speedztr 36 zero turn mower and wanted to know what kind of hydro system it has and when the components are located.? I am getting a "winding" noise when I use the hand sticks to...
the winding noise indicates that the fluid in the axel is low. find the center of the axel and you will see either a square nut or a square cut out for a 3/8 wratchet to fit remove it and the fluid shoud be at the very bottom edge of the opening if not simply put 80/90 gear oil to fill it. you fill till it starts to run out the hole then put the screw back in and your done.
May 28, 2014 | Ganassi Target Dallara Indy Car Scott...
Dixon speedztr belt is loose when I try to engage won't work
Apr 20, 2012 | Garden
How do i replace a bearing on my center pulley on a dixon ztr ram 44?
Apr 14, 2012 | Garden
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
