Question about Fisher and Paykel Washing Machines
Hi I've turned my machine on (F&P Intuitive Eco) and it makes all the noise when turned on, but after that, the power board doesn't come on. It was working perfectly fine yesterday. Please, please help
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.If your machine does not power up when you turn the power on at the power outlet then there are 2 reasons for this,The 1st is your drain pump is faulty or 2nd your control module is faulty.Would you like help in the testing of the pump to see if this is the fault.If it is the pump that is faulty then the control module should be alright but if the pump is not faulty then the fault is the control module.Also check the power outlet with a small appliance to see if there is power there.Looking forward to your reply.
Posted on Oct 03, 2010
2 Suggested Answers
SOURCE: what is code 37 intuitive eco
replaced the water pump. It was failing intermitantly
Posted on May 06, 2009
Why is the pump make a terrible noise on my F&P intuitive eco washing machine
it just needs a bit of crc or similar sprayed on the front and back pivot bushes
Jul 04, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
My Fisher & Paykel intuitive eco washing machine starts the drain pump as soon as the power is turned on and continues pumping when no water present. It also displays "help, i need water" at...
Hi - this is a strange one - I could be wrong here but I think that theres two likely possibilities for you - first is the motor controller board could be faulty - it may have a short on the switch ic for the drain pump - the other is there maybe an air lock or blockage to the pressure tube - remove the display panel to access the clear tube - unclip it & blow into towards the bowl to see if theres a blockage.
You say as soon as the start switch is pushed the pump runs continously? or does it come on as soon as the power button is pushed? either way I think the controller maybe faulty - haven't come across aything like this one before...
Cheers
Aug 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco w.machine showing error code 130 and sometimes 240
switch the power off for a little while minute or 2 & turn it back on and press the power button and pstart the cycle again.
Apr 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco - no power
Definately need to get a service man out. Sounds like the computer board has failed & the tech will need to check if another part was the cause of the board failure.
Sep 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Noise in wash cycle
This is normal, because your washer will make sounds that you may not have heard from other washer.
Jun 07, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
27 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
