Question about Lexmark P4350 All-In-One InkJet Printer
Paper jam error message
I have a lexmark p4350 printer about 3 months old and used very little. Hadn't used for 2 weeks and now when I go to use it it tell me it has a paper jam. What it does is take paper about one third in then the paper stops but the printer continues to print until its done then it tells me I have a paper jam. There is nothing printed on the paper it took in and it pulls back out easily. I read lexmarks trouble shooting tips with no luck. Any help I would gretly appreciate it
  • 549 Answers
Try this website for a paper jam problem with your printer.
Click Here
Posted on May 26, 2008
I have Lexmark p4350 I can not copy, and show error 2200
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
Sep 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
...Still "paper jam". I did
This article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on the Lexmark P4350/P4330 Photo All-In-One will help you fix the paper jam problem. However, if problem continues, there could be some sort of foreign objects that fell into the paper feed system. Grab a flashlight and look into the feeder for any foreign objects that's in the paper path or, if you are capable and willing, carefully lift your printer upside down so the foreign object will freely roll out from the feeder.
Apr 03, 2011 | Lexmark P4350 All-In-One InkJet Printer
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
My printer wont load paper just takes it a little way in then says paper jam p4350
Clean your printer, in side and out with a can of compressed air followed by a vacuum.
Apr 29, 2009 | Lexmark P4350 All-In-One InkJet Printer
Paper jam
I had the same problem, managed to fix it after a few tries by shutting off the printer, raising the scanner unit and pushing the ink cartridge unit all the way to the right and back to the left, when the printer was turned back on the error was gone and printing continued normally. Hope this will solve the problem with anyone else. racv2_2001@hotmail.com
Jan 21, 2009 | Lexmark P4350 All-In-One InkJet Printer
Blank paper new(ish) cartridges
They are clogged. Soak the print head in hot tap water for a few seconds, dry and re-insert. Then run the cleaning program. If this does not work, then you need new carts.
Geno
Mar 05, 2008 | Lexmark P4350 All-In-One InkJet Printer
P4350 paper jam error message. Definately no paper jam!!
try to follow the paper path as best as you can, from where the paper is picked up till it comes out, visually do this with the printer off, there should be a sensor (small plastic part that moves a little this tell the printer where the paper is at during the printing process, this sensor is probably stuck. 9 times out of 10 this is the problem.
Dec 27, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Printer feeding paper uneven and jamming
to be honest mate I am quite gutted myself before I purchased the p4350 I had an x1130, similar printer ie, all in one which lasted for about 3/4 years..but it recently stopped feeding paper. ie.. feeds it in on the right hand side and then gets stuck.. same problem. so I decided to replace it and purchased the p4350.. as i thought the problem was a one off!! But oh no.. i AM VERY SURPRISED THAT AFTER ABOUT A MONTH this printer has done the same thing!! I am hapy yours is too as i know it is not something I am doing wrong!! I can't personally find a solution to the problem. luckily I can replace it easy enough because I got a replacement cover out on it... BUT I won't be changing it for another lexmark! and I am just going to email Lexmark now as their paper feeding mechanism seems very poor as many other people are experiencing the same problems with different Lexmark printers!!
Nov 25, 2006 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
