Question about Dishwashers
Rinse only light is on and all of the wash rinse sanitize clean buttons come on and flash when you try to start it, if you change the setting to normal or heavy duty the wash light comes on then the rinse only light comes on and all above mentioned buttons flash until the tub is drained.
  • tkce Oct 02, 2010
    Thanks Daniel, turned the power off for 20 minutes and turned it back on, Dishwasher seems to be running normal.
  • 4,323 Answers
Hi
Try and reset the dishwasher by unplugging it for 5-10 minutes. Now check if you are still getting the same error you can try and press the following buttons to reset it--
Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 02, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
215 people viewed this question
Top Dishwashers Experts
