Question about Logitech Cordless Mouse
How to open mouse to replace battery - Logitech Cordless Mouse
Replacing battery
Need a screwdriver. Unscrew the back of the mouse. Usually there's a compartment where the battery is isolated.
Apr 02, 2014 | HP DC172B Mouse
Microsoft basic optical mouse v20 usb battery
To open the battery compartment slide the switch under the mouse to open the lid. take out the two batteries and replace them with new ones. Replace the lid.
Nov 29, 2013 | Microsoft Wireless Notebook Optical Mouse...
How do I open wireless logitech mouse to change batterie. I do not want to break anything by forcing it open
hold your hand on the bottom of the mouse on the battery door and then your other hand on top of the mouse and push that hand outwards while pulling back with your other hand.
Mar 01, 2011 | Logitech Cordless Mouse
How do I change the battery for my logitech cordless mouse? Can't find opening for battery....
hi marlys, i am happy to assist , Ya its not too easy to replace battery in logitech cordless mouse,in the back of mouse, you have mouse pad just remove it , you can see they provision to remove the mouse, there been Four screws been inside that mouse pad, But before going to open your mouse just check you have new battery with you, if you connt find in any shops just go to eBay , you can get it thee, If you mansion the excate model name of your mouse mean i will send video for that particular model itself , no issue just check out this video
Jan 06, 2011 | Logitech Cordless Mouse
How do I replace the battery on my cordless mouse
Step 1 change-wireless-mouse-battery-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.1-800X800.jpg'); }); Exposed batteries of a wireless mouse Flip your mouse over and remove the battery cover. Gently pull it up and set it down in a safe place.
Step 2
  1. change-wireless-mouse-battery-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.2-800X800.jpg'); }); Carefully remove each battery.
  1. Step 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
Step 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Good luck.
May 09, 2010 | Logitech Cordless Mouse
How to open to replace battery?!
Check the manuel for opening the battery cover. Otherwise go through the product review in the company website.
Dec 09, 2009 | Laser Logitech O - Mx400 Performance ...
How do I open the mouse to change the battery?
Turn the mouse upside down. push the tab and open door. pull out batteries and replace with same type. make sure batteries are loaded as per diagram on inside of compartment
Nov 21, 2009 | Logitech Cordless Mouse
How do I open to replace the battery on my microsoft wireless optical mouse 3000
There is a release button on the mouse that allows you to slide the top back of the mouse off. The button will be on the bottom and labeled "OPEN". Press this as you slide the top cover off. From there you can replace the batteries.
Nov 17, 2009 | Microsoft Wireless Notebook Optical Mouse...
Open mouse to replace batteries for giga ware mouse
Press the small buttton on the lower palm side of the top of the mouse and pull the round side of the mouse off. you tube video here http://www.youtube.com/watch?v=A3fYOjdAE1g
Feb 07, 2009 | Gigabyte Wireless Optical USB Mouse GMW7C
How do you open Logitech laser cordless mouse to replace batteries?
puhs open the logo area (palm area), toward the backend. it takes 2 aaa battery.
Nov 04, 2008 | Logitech Cordless Mouse
Logitech Cordless Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
