Question about Dell Inspiron 6400 Notebook
The two LEDs in the middle flashes continuously and the laptop remains as if not working at all, ever the blower fan does not run.The LEDs go off after some time
  • 734 Answers
I think you might have one of 2 issues:
Your CMOC battery needs replacing
or
It may be as simple as Bad Ram
Posted on Oct 02, 2010
Blower relay
This sounds like it's your radiator fan or engine bay fan continuing to run due to the hotter weather we are having. Some fans are programmed to cool the engine bay area if their thermostat triggers them. These conditions usually happen when weather becomes very hot and triggers the system to continue the fan due to excessive heat in the engine compartment. Usually not a bad thing and should stop when weather cools down. What is worse is if the fan doesn't work. Keep an eye on it and see if it continues to do this when weather cools down.
Aug 24, 2013 | Mitsubishi Cars & Trucks
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
IN THE MIDDLE OF COOLING THE AIR CONDITIONDER ( OUTSIDE UNIT) STOPPED WORKING AND THE BLOWER MOTOR CONTINUED TO RUN PUSHING AIR THROUGHT THER HOUSE. THE THEREMOSTAT CONTROL WILL NOT SHUT OFF THE...
make sure your thermostat is not set run the fan,
is there an auto/on switch on the thermostat subbase?
if so then switch it to the auto position
Jun 17, 2011 | Heating & Cooling
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
Mitsubishi air con MSH18NV - blower goes off - LEDs remain on
Sounds as though you have a bad motor. Once the motor heats up the winding swell causing the motor to constrict itself. Once this happens a thermal overload switch kicks in shutting the motor down to prevent fire. Hope this helps you Philip. Good luck on your repairs
Dave
Sep 15, 2009 | Mitsubishi MSH09TW Air Conditioner
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
GOOD LUCK, EVERYONE!!!
Mar 12, 2009 | Dell 1700n Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
Feb 24, 2009 | Dell 1720dn Laser Printer
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6400 Notebook Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
