SOURCE: HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
SOURCE: Tv picture not all showing up
this is like the conversion Ic's that is for projection tv's, but different for an lcd or plasma tv , it will need to go to the shop where they can order the board to correct this problem. these boards are not available to the public. you can try to replace any components on the video processing board that are bad , like electrolitic caps , surface mount resistors , diodes , but if it is a surface mount chip then you will need the whole board , because thats the only way to get it
electech
SOURCE: fuzzy picture on my 42" akai lcd tv
Get rid of the pice of ****... mine did the same thing about 6 months after warranty
SOURCE: motion problems
You need to contact cable company, first for this.
Because of tyhe picture quality is related cable box, cables ,connectors & etc.
SOURCE: shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
