Question about Whirlpool Dryers
When you turn it on it doesnt spin to tumble dry
  • chase1616 Oct 02, 2010
    Teh belt is intact and I can turn the drum by hand which in turn turns the belt
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 03, 2010
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Dryer heats, tumbles but does not dry. Exhaust has heat.
perhaps the washer is not spinning all of it out therefore making it hard for dryer
Aug 31, 2015 | Dryers
How do i tumble dry only on a lg hover wash machine
Washing machines don't have tumble dry. That would be a dryer. The best you can do with a washer is spin cycle.
Nov 08, 2014 | LG F1481TD5 1400 Spin 8kg Load Washing...
Tumble dry wont turn and dry
check that your motor spins and your belt is on the drum. you say its heating so your door switch isn't the problem.
May 30, 2014 | Cell Phones
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Can you put a sleeping bag in the tumble dryer?
Mostsleeping bags can be tumble dried but on a low heat. Check out this article forsome more information about drying and generally cleaning sleeping bags http://www.rei.com/expertadvice/articles/caring+sleeping+bag.html
Jul 30, 2012 | Camping, Backpacking & Hiking
I have a TB condensing tumble dryer, model TM310W, which has always worked well, but lately, although the clothes are drying, there doesn't seem to be much water going into the reservoir. I can't find it...
The first decision you must make when buying a tumble dryer is whether to buy a vented or a condenser dryer. As you'd expect, there are pros and cons for both. This page helps you understand all of the differences, including the reliability and repair implications. Condensor tumble dryers are becoming more popular but vented tumble dryers still have some advantages and the convenience of not needing a venting hose (as always) requires some compromises.
Until I can put together my own reviews the best Tumble Dryer reviews available online are by Which?
Due to their resources and independence, Which? usually have the latest reviews and collect the opinions and experiences of thousands of members - Which? tumble dryer reviews (Plenty of free information but will need to be a subscriber (take advantage of the 1 month trial offer to get the full benefit)
Vented tumble dryers are cheaper than condenser dryers, they are also simpler, more reliable and more economical to run. According to Which? "on average, vented tumble dryers use about a fifth less energy than condenser dryers to dry a full load of cottons."
So why bother with a condenser tumble dryer? Well condenser tumble dryers are a convenience product but they do offer a solution to a genuine problem for some where venting the dryer outside is difficult or even impossible.
My advice would be that if your tumble dryer can be sited somewhere that allows you to correctly vent it outside, either through a wall or through a window, then a vented dryer is probably best. If this would be particularly awkward, then buy a good quality condenser dryer, which should condense the steam into water.
Modern washing machines now have a far superior spin speed, and, of the ones we recommend, the cheaper model has a 1200 spin speed, the other a 1400 spin speed... so your washing will be fairly reasonable (some items could be about ready to iron) and this, in turn, could affect your other choices.
Could you get away with just airers and a washing line? Or have you considered a dehumidifier?
A Spin Dryer... will work efficiently, and is cheap. The main advantage to it is that it is only the size of a large pedal bin, so it can be stored under the worktop in a small amount of space.
A Tumble Dryer... much more expensive... for a decent quality item you need to pay a quite steep price. They do a good job, but are another full size kitchen appliance to find room for.
A Washer/Dryer... instead of a washing machine... disadvantages, if it goes wrong then you have no back up in either the washing or drying department... and of course being a more complicated piece of machinery, it IS more likely to break down! The only advantage is that it will be a space saving item.]
please comment on these on how helpful.
Dec 21, 2010 | Electrolux Dryers
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Washing machine trouble
i need more info but can help front loader top loader brand etc
Dec 30, 2007 | Washing Machines
Dryers Logo
29 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
