Question about Microsoft Windows 98 for PC
Windows 98 will not load.
When I turn my computer on it shows this C:\> in DOS a friend told me to type in win. After that it tried to reboot but I got the following message,
VFAT Device Initialization failed. A device or resource required by Vfat is not
present or is unavailable. Vfat cannot continue loading. System halted. Please help!
  • nowin May 26, 2008
    Thanks it worked like a charm.
    Scholar:
  • 110 Answers
There is a Microsoft article that gives a number of steps to follow to try and rectify this problem. You can view it here and come back to us if you still have problems.
Posted on May 26, 2008
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Computer turns on and after its done showing loading bar a blue screen appears . the computer then restarts with a black screen showing start windows normal, or startup repair. i chose startup repair
Try running the Check Disk Utiltiy.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 25, 2012 | Computers & Internet
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Does not load Win98se
Robb4. Use fdisk to make active partition and reformat.
Jan 25, 2008 | IBM ThinkPad T20 2647 Notebook
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Missing or corrupted files
get the 98 start up floppy and stick it in the a:/
Copy command.com, or anything else missing to your c:/ from the floppy. type help/? at the c:/ and you should find the proper format for the version of DOS you have.
C:/copy a: c:
Oct 21, 2007 | Computers & Internet
Gateway 7330GZ will not follow through at start up
At startup, hold down F8 key. select safe mode start. allow windows to guide you from there. if no-go, then repeat but choose dos prompt only, then insert a win 98 startup disk and run scan-disk on your drive. if no-go, in worst case, try to delete the pagefile.sys file from dos prompt (you may need to change file attributes from read-only and hidden and system to toggled-opposite-read, not hidden, not system). and repeat above steps
May 27, 2007 | Gateway 7330GZ (890552601318) PC Notebook
Microsoft Windows 98 for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
