Question about Microsoft Xbox 360 Console
Dvd drive my dvd drive wont eject n da middle green light on da power button is blinking green continously n will never stop. n e idea what da hell these means?
  • hank da tank May 27, 2008
    hey GUEST, why don't you go back to elementary school so in that case you will understand what i'm trying to say! maybe you don't own an xbox 360 so shut your faggy mouth.
It means spell your words out so we will understand what you are trying to say!
Posted on May 27, 2008
I own a acer aspire az3101-u4062. everything seems to work normal except i cant open the dvd drive
Look carefully at the front of the drive, near the eject button. There maybe a small hole. If there is insert a straightened paper clip and the drive will open.
Nov 17, 2014 | Computers & Internet
The dvd wont open on the computer
if there is any led blinking on dvd drive while pressing eject button , blinking led indicates that the logical section of drive is ok , there is problem with some mechanical components. if no led blinking occurs, u must be having a loose connection of power else a faulty logic board of dvd drive
Sep 28, 2013 | Compaq Computers & Internet
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My CD drive wont open, no idea whats wrong? Help? Toshiba Satellite L505 running Windows 7
Sounds like there's no power going to the drive, or it's jammed.
Stick a paperclip into the hole on the drive's faceplate. This should manually eject it. Close it and you should see a blinking green light, if not then the drive is not getting any power.
Dec 31, 2010 | Computers & Internet
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
Original xbox continous blinking green light, no eject & loading
sounds like a bad cable between the console and the TV, the XBOX is notorious for having issues if the cable isn't the correct one (a Microsoft one) or damaged.
the flash green with nothing else happening can be a failed bios.. coma console variant. It's possible to fix it with a chip, but uneconomic considering the price of a working box these days. It can also be a failed ide controller or bad ram..whatever, it's normally a scrapper with these symptoms unless you have a good junkbox...
If you have an xbox that fell it's always worth changing over the dvd drives, as they can cause weird faults as well, (as mentioned above re: unknown disks) as the green flashing is the usual "loading disk" message.
Sep 08, 2009 | Microsoft Xbox Console
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
Xbox360 tray ejects itself
The only thing i can think of is that something is stuck in the tray. Sorry about your luck
Apr 30, 2009 | Microsoft Premium System for Xbox 360
The power button on my Philips DVD player blinks.
The Front PCB might be damaged. Check the front PCB
Jan 10, 2008 | Philips LX3000D System
Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Apr 17, 2007 | LG GSA 4163B DVD±RW Dual Layer Burner
Microsoft Xbox 360 Console Logo
91 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
