Question about Konica Minolta magicolor 2430 DL Laser Printer
After you print a label you get Black marks all down left side of the paper what wrong ?
  • Konica Minolta Master
  • 4,737 Answers
I suspect the Waste Ink tank full issue. It is highly recommended to clean the Drum's waste ink tank, to do this, you'll need to disassemble the drum and remove the wasted toner. When the waste ink tank is overflown, the toner power is spreaded on the paper with the toner from the cartridge and makes the print out very bad with ink spread over the paper or splattered.
Please check the drum bar that there's no toner power stuck and make sure to gently blow them away (never touch the drum bar with your hand or any other foreign particles, since it's very sensitive). Also clean the cartridge and the fuser unit. Remove the cartridge, drum, fuser and blow through the passage with a blower so that all the accumulated toner would be cleared.
After everything is cleared and cleaned, reinstall all the components and try again. If the print quality is improved, you'll better replace the drum.
Let me know when you are done.
Good luck.
Thanks for using FixYa.
Posted on Oct 02, 2010
I have a HP Photosmart D7160 and it won't print 4 X 6. It has black marks on the wrong side when it comes out, but not picture
Try flipping the paper. Probably you need to resize the image for this size, sounds like it is compressed and squnched together into those black marks. See if you can use a preview function.
Jul 31, 2016 | HP Photosmart D7160 InkJet Printer
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
Printing avery labels
Black ink printing on the reverse? On the wrong side of the page? I hate to ask, but is it possible that the labels just need to be turned the opposite way when you put them in the printer?
Mar 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
My dymo labelwriter 450 says its out of paper when I try to print a label. When its initially connected the printer says "ready" as soon as a print command is made it says it's out of paper....
Hi, I had this problem and found that the labels were rolled up the wrong way, make sure the series of horizontal black lines on the labels are nearest to the left side of the printer as you look at it, this worked for me, hope it helps - Paula
Jun 19, 2011 | Dymo LabelWriter 400 Thermal Printer
How do i print envelopes on the HP 1350?
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
Dec 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
Schiller AT-2 Plus, placed new paper in machine and machine keeps stating "out of paper" and will not print unless I hold down the manual print.
Your machine has the wrong paper in it or the paper sensor is not working properly.  There should be a black mark on the top left hand corner of each page.  The correct ekg paper and ekg repair is available from Medical Device Depot.
Feb 15, 2010 | Schiller Welch Allyn Cardiovit At 2...
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Changed roll of labels, now it won't print...
Warren
one side of the paper will be sensitive to heat and the other side won't be. If it is thermal paper run a pen without the actual ink part sticking out of the pen or use a key from your key ring in your pocket over the paper the friction should leave marks on the thermal side of the paper.
you may have the paper in with the non thermal side facing the heat printing part of the paper. Or you have the wrong paper.
http://www.microtrade.com.au/zebra-printer-ribbon-suits-tlp2824-plus-label-printer/?gclid=Cj0KEQiAuonGBRCaotXoycysvIMBEiQAcxV0nOLqC5Do2fiZih4Z19jw389fNmbkQXNwgUfYVzkqdSgaAhbc8P8HAQ
ld4028-10a or ld21084 may be the label ? not sure its 40 mm wide not 55 mm or 2.2 inch
Mar 10, 2017 | Zebra LP 2824 (clp2)
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
48 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
