Question about Polycom SoundPoint IP 550 IP Phone
Trying to connect my office phone to my home PC. 1. Yellow cable from Polycom Soundpoint IP 550 SIP phone to PC can be hooked up no problem. 2. Black LAN cable: a. There are two cables coming from the wall socket. A green cable that connects to a “phone” socket in the back of At&t 3800HGV-B hub/modem (?)/(internet and U-verse TV). The grey cable connects to a “phone 1 & 2” socket. The LAN cable will NOT fit into either wall socket. b. In the back of the At&t hub the LAN WILL fit into 2 available Ethernet sockets. There is a “broadband” and “aux” socket available but has tape covering the socket. c. If I plug LAN into Ethernet sockets I get display message ‘COULD NOT FIND BOOT SERVER WITH EXISTING CONFIGURATION”. When the phone initializes I get flashing message “Sunday, December 31, 4PM”. If I pick up phone the display message is “URL CALL DISABLED.” 3. Appears that At&t is not compatible with LAN, or I need another piece of equipment (router or?) to complete hook-up. HELP?
  • 2 more comments
  • gene_hirai Oct 02, 2010
    Two of my co-workers take this phone from the office to their home over the weekend and are able to connect with their home PC. I've left messages for them but was hoping fixya could assist me sooner. Thx
    Appreciate last 2 responses but still get display message on Polycom 'COULD NOT FIND BOOT SERVER. The only place the LAN line (running from the phone)fits is in the back of the at&t 3800HGV-B hub (?)that says "local ethernet 1,2,3, 4 slots. Any suggestions?
  • gene_hirai Oct 03, 2010
    Sheila,
    Thank you so much for your guidance. I'm obviously a novice but you write with clarity and common sense. You made my day! ~Gene
    Sheila wrote with clarity and her solution makes sense to a novice. Appreciate everyones input. ~ Gene
  • 2,973 Answers
Gene,
The computer connectors are so designed that only the correct can be connected to the correct socket. So if it fits it is meant for that socket.
At boot up please press F2 and enter the BIOS. Here look for Boot up sequence. Your PC seems to the set to boot up from a LAN server. Change it to HDD.
You do need a router. Whether a wired or a wireless is your choice.
Posted on Oct 02, 2010
    President:
  • 3,278 Answers
Hello, Gene.
If you haven't already, reset the modem/router.
Hope this helps.
    President:
  • 2,777 Answers
These phones definitely need a specific type of phone network behind them, they do not work with just a home style phone connection and a regular PC. You will need someone to come to your house and re-wire your existing phone setup if you desire to use this phone system. Also you will need a phone server (computer) that has the configuration for the phone and will log and route some types of calls.
Basically it is a very extensive and expensive routine to get this phone up and running, I would not recommend it for home use. Usually these models of phone are used in a setting where hundreds if not thousands of the handsets are in use, and then it makes sense to have servers for them.... for your case I think you may want to go with another style phone.
Thanks Tim
3 Suggested Answers
SOURCE: Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Posted on Sep 27, 2009
virusi
  • 95 Answers
SOURCE: what is the default password for Polycom
Default Passwords:
To get into the web interface, the default username/password is "Polycom"/"456" (Note that this does not work with Safari 1.2.2.)
To get into the Admin interface on the hard phone, the password is "456". (Prior to v1.3.1, the web interfaces to the phone uses "Polycom"/"SpIp" as the username/password.)
The "user password" (not used much) defaults to "123".
To reset a lost admin password to default: at phone boot, during the 5 second countdown, push/hold 468* on the phone. Enter the phone's MAC address as the password. This will reset network info but keep peers loaded. Tested on Soundpoint IP 650.
Posted on Dec 22, 2009
Testimonial: "Thanx a lot. Although I had managed to find the password for console but the web interface password was still missing. :-)"
One of our Polycom 550 phones keeps randomly
It is not your T1. The T1 only controls the internet, not your local LAN. How old is the phone? It could be a bad phone....What system is it installed on?
Jan 08, 2010 | Polycom SoundPoint IP 501 IP Phone
What is the default password for Polycom Soundpoint IP 320 SIP?
Default Passwords:
Dec 22, 2009 | Polycom SoundPoint IP 320 SIP IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Dec 16, 2008 | Polycom SoundPoint 330 IP Phone
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom SoundPoint IP 550 IP Phone Logo
187 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
