Question about Whirlpool Duet GHW9150P Front Load Washer
Error f 35 - Whirlpool Duet GHW9150P Front Load Washer
    Genius:
  • 1,416 Answers
This error code on a washer machine indicates a keypad short on the washer Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourself offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hop this information helps you.
thanks.
Posted on Oct 02, 2010
How do I set my Cobalt LDM-35? Error 208. Won't measure
Kobalt Ldm-35 - Power Tools Best Sellers Reviews
kobalt-tools.top-100-bestsellers.com/kobalt-ldm-35.html
Best Kobalt Ldm-35, Kobalt Tools for sale - Bestsellers Catalog Online helps ... LDM 35 Error 208; Kobalt Laser Distance Measurer Review; Kobalt LDM 35 ..
Sep 08, 2015 | Cars & Trucks
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
Konica error 35
Error F35 for Konica seems to be "low fuser temperature" error.
Could be a sensor or the fuser unit itself.
You should also try turning off the unit for about 10 minutes (unplug) and then restart it.
Apr 08, 2014 | Office Equipment & Supplies
Error 35
The error 35 I can't find. Canon does not like to tell all details.
10,20,30,40,50,60,70,80 are for: Can't make a picture because of an error. Switch the camera off and on.
If the error comes back, please contact the canon service center closesed to you.
This is all I can find for errors above 10
Nov 08, 2013 | Canon Cameras
Error code 35
error code 35?
error codes on the minolta print /copy machines usually have a letter followed by four digits e.g. C2035,
please indicate which model and exact error code with a description of the error as seen by the user.
Sep 25, 2013 | Konica Minolta Office Equipment & Supplies
There is a error code 34 35 in my kawasaki z750,2008.let me know the reason for that
Error Code # 34 - Exhaust butterfly valve actuator sensor malfunction, wiring open or short. Error Code # 35 - Immobilizer amplifier malfunction (Equipped Models) These are the exact error codes from the service manual itself. Good luck.
Sep 16, 2013 | kawasaki Z750 Motorcycles
'unable to clean 35' error on mfp brother dcp-j125 printer
Feb 15, 2012 | Office Equipment & Supplies
Error 35 on Brother MFC760
Common Error: Carriage cannot move midway thru travel.
-clean the encoder strip
-check for any foreign objects inside
Sep 04, 2009 | Brother MFC 760 InkJet Printer
I have a problem.error code 35-000,DSR 1500AP.what is this?
error 35-000 on a dsr-1500 is a cassette compartment position error. check to see if something is obstructing the movement of the cassette compartment.
Jan 23, 2009 | Sony DSR-1500 Mini DV VCR
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
