Question about Samsung AS18A6RB Air Conditioner
After insert the code of AQV18FAN ( Leds Blinking) the indoor - outdoor units are OK ( cool-heat ) , but All LEDs are OFF , when the units is ON .! Why? The R-G-Y leds OFF .Even Power Green Led is OFF when the indoor unit works in cool or heat
3 Suggested Answers
SOURCE: my split-type aircon is contantly
there isa circuit problem in ur ac
Posted on Nov 09, 2010
SOURCE: After the code numbers in samsung AQv18fan , the
When I turn on the air con. after 30 min. about it stops working, and the red turbo button get lights. End now it works but not heating, just working?
Posted on Nov 21, 2010
The outside unit leds have a 29 code, before it goes into shutdown. Outside is a LAU180HSV Invertor V Split System. Installed in 2012.
That code means that the compressor is drawing too much current when it is trying to start. It is highly unlikely that the main board is bad.
May 04, 2016 | LG Art Cool LA180HSV 18,200 BTU SingZone...
Hi my lg inverter v is blinking lights when I switched on and not heating. when inspected out side, found the unit was buried in snow. so, I tried to switch on after clearing all snow and the fan too...
PDF]DEFINING COMMON ERROR CODES
www.lg-dfs.com/.../DFS-TP-AG-001-US_012H29_LGTechPaper_Error...
Aug 29, 2012 - Art Coolâ„¢ Mirror High-Efficiency Single Zone Systems ... Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot ... Location of light-emitting... No. of Times Indoor Unit LEDs Blink ... Inverter compressor DC voltage is too high.... unit inverter compressor PCB heat sink temperature is too high.
[PDF]"Universal" Split Systems - LG Comfort Cooling
Jan 23, 2016 | LG Heating & Cooling
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
I have a error message f1 on my air con
F-1-Noc ommunicationbetween indoor and outdoor.Check connections and LEDs. If OK replace either main or fan PCB
Jan 15, 2011 | Mitsubishi MSZ-A15NA Split System Air...
After the code numbers in samsung AQv18fan , the unit is ok , but all LEDs , in the power on of unit is OFF .!!
Oct 02, 2010 | Samsung Heating & Cooling
The unit simply goes off (one of the leds would blink) then you have to restart it again and again several times per day
You can try to clean the filter and also the outdoor side condenser fins which may have dust and dirt. The indoor filter simply slides out of the front panel. The outdoor side can be sprayed (while unit is off) with a hose.
Nov 06, 2009 | LG Electronic Window Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Heat/ac pump
- If it is a high wall unit yep under charge refrigerant is one of the cause.
- Out of range thermistor is also can also be the cause of tripping outdoor unit with matching blinking light same as low refrigerant.
- Dirty indoor and outdoor can also be the cause
HOW TO CHECK IF YOUR UNIT IS OUT OF FREON
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
Jan 08, 2008 | Heating & Cooling
Samsung AS18A6RB Air Conditioner Logo
95 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
