Question about RTO PasLode 900420 Impulse Framing Nailer
Hammer does not return after shooting - RTO PasLode 900420 Impulse Framing Nailer
  • 2,176 Answers
Could be a nail jammed in the magazine area, bent driver or just dirty and needs a good cleaning and relube. let me know and I will try and help with anything I can
Posted on Oct 03, 2010
Ryobi problems
Check to make sure you don't have a staple stuck under the hammer. If the spring feed is working, then something is keeping the staples from sliding under the hammer. Can you hear the hammer hitting? Does it leave an impression on the wood?
Jul 29, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Why does my roofing nail gun jamming, it would fire one nail and the hammer will remain out, so i toke a screw driver and push the hammer back in, and it still did the same thing
Simple test for piston jam. With nails removed and latch open, point nose of gun up then down. If the driver slides up and down in the cylinder as you move the gun, replace the piston oring (test gun for proper operation). If the piston stays in the upper most position as you move gun (push driver to top position), check lower bumper and bottom seal under the bumper (sheet). Replace as needed. If the lower parts are in good condition (good piston oring, lower bumper and sheet) , replace the 3 orings on the feeder piston. Good luck
Dec 03, 2011 | Hitachi NV45AB2S Coil Roofing Nailer
Staples will not shoot flat. Have to hammer them
well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Jul 22, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Brand new gun seems to be in good working order,
If nothing is jammed the the hammer that hits it is probably not hitting could be bent,you can try cleaning and putting about 1/2 load in it .if not shouting then it isn't in good order / if new way not return should be warranty/defect
Mar 20, 2010 | Air Tools & Compressors
My tippmann 98 custom pro is shooting automatic by itself... i just installed my etrigger but when i hook the co2 up to it, it shoots automatic
The reason for this malfunction can be caused for two things, one is that the trigger is not sitting right or one of the springs is not in place another reason that may cause the problem is over lubing the hammer, but must likely is the trigger not holding the hammer in the rear position until you pull the trigger. Hope this helps.
Mar 05, 2010 | Tippmann 98 Custom Act Paintball Gun
Intermitant fireing and the hammer doesnt return to pick up the next nail
If the hammer isn't returning, that is usually a sign of needing oil. Also, new guns that aren't broken in yet can do that as well, but oil usually helps them too.
Oct 22, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Plunger want retract
The hammer could just need to be oiled or you could have blown a seal in the gun which is not expensive to fix around 20.00 . A lot of times when my gun jams on a nail it gets stuck so the hammer won't go down. I just use something thin that will fit on the hammer and take a hammer and just tap it back into place.
Aug 12, 2009 | Stanley Factory Reconditioned Bostitch...
No hammer effect, motor work OK
First try the switch for hammerdrill/drill action. If it feels loose, then its internal. if it feels ok, then your hammers on the cage are stuck, frozen or worn.
Jul 17, 2009 | Hitachi DH38YE 1 1/2" Spline Rotary Hammer
Staple gun has staples but quit working.
I hae the same problem. I don't know the real names of the parts so I will make up my own and try to describe them. The problem with mine is that the "hammer" (the piece in front that slams down on the staple and shoots it out) is broken. The "hammer" has two notches that the tension spring (actually a metal bar with two tongs not to be confused with the spring the returns the handle to the at rest position) fits into. One of these notches on the hammer is broken. Therefore one side is not attached to the tension spring the causing the other side to slip off and since the hammer is not connect to the tension spring you get no resistance. Unfortunately I could not find anywhere that sells a replacement peice.
Sep 18, 2008 | Black & Decker 5700 Powershot Forward...
RTO PasLode 900420 Impulse Framing Nailer  Logo
95 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
