Rca mp3 opal says reboot - Audio Players & Recorders
  • 2 more comments
  • Anonymous Mar 19, 2009
    i was uploading songs onto my mp3 player. when it was done, i unplugged it from the computer and it said it was loading. it was taking longer than normal to load, so i pressed the reset button. i then tried to turn it on, but it said i needed to reboot the system. how do i reboot it so that i can use it again? thanks :)
  • mstanford78 Mar 31, 2009
    I have tried to update software and what you said to do disconnect and hold volume+ and reconnect and hold for 5-50 more seconds bit it sti;; says the same thing Boot Error! Please Format Unit. Any other suggestions?
  • Anonymous May 02, 2009
    I have a problem with my RCA mp3 from wal mart in norwalk
    for three months a rain drop hit the pause button on the mp3
    how do i fix it
  • nytrell May 03, 2009
    mps is frozen
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 27, 2008
How do i put videos on my opal mp3
Log onto the RCA website and download the RCA SMV Video Converter. The Opal only plays videos that are in one specific format. This converter will put your videos into that exact format (see Resources below).
  • Install the RCA SMV Video Converter once you have downloaded the software.
  • Open the RCA SMV Video Converter software to begin putting videos onto your RCA Opal.
  • Connect the RCA Opal to your computer using the USB chord that came with the device.
  • Wait until the RCA SMV Video Converter software reads that the device has been connected. You will know this when the bottom of the software screen reads “Player Detected: Opal 1GB 2GB.”
  • Select the “Browse” option to find any videos that are on your computer which you wish to add to the RCA Opal.
  • Click the box next to “Transfer output files to OPAL 1GB 2GB after conversion is complete” after you have selected all of the videos which you wish to convert. This will automatically add the videos to your RCA Opal after they have been converted.
  • Click the “Convert” box after you have selected all of the videos. The videos will automatically begin to convert to the correct format. Once they have been converted, your videos will automatically upload to your RCA Opal.
  • Oct 04, 2009 | RCA OPAL M4001 MP3 Player
    How do i fix my rca mp3 model m4204
    you find the reset button and there ya go
    Sep 21, 2009 | Audio Players & Recorders
    My mp3 won't charge at all
    If when you plug into usb cable dose it show that a device was pluged in ? If it dosen't turn on then youre charging cable is bad. If cable isn't bad remove software from youre computer using remove programs, unplug opal from usb then reboot youre software for youre rca opal cd.
    Mar 09, 2009 | RCA OPAL M4001 MP3 Player
    RCA Opal MP3 Player Deleted it's software
    RCA Opal - Stuck on "Initializing"
    (Update - the website changed once again to www.rcaopal.com)
    Go to this website to reload the firmware:
    http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1415&p_created=1202430585&p_sid=CwOaz8ej&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTIsMTImcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1pbml0aWFsaXppbmc*&p_li=&p_topview=1
    Note: websites are subject to change - if you go to http://www.rcaaudiovideo.com and go to the page for the RCA Opal m series, you can also find the firmware reload on that page.
    Feb 16, 2009 | RCA OPAL M4001 MP3 Player
    Won't do... anything...
    The hold switch is on
    Fatal error on RCA Opal:
    What do I do if I experience a Fatal Error? How Do I reset my Opal?
    The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
    Right click on the device within the Explorer or My Computer window
    Select the format command (full format) to reformat the internal memory of the device.
    Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
    -Tha Mp3 Doctor
    Sep 21, 2008 | RCA OPAL M4001 MP3 Player
    Rca m4204-a
    -Tha Mp3 Doctor
    Aug 30, 2008 | RCA OPAL M4001 MP3 Player
    MY COMPUTER WANT RECOGNIZE MY RCA OPAL MP3 PLAYER
    One solution is this. Keep the Opal plugged into the usb and reboot. I did that and only then did it recognize my player.
    Jun 29, 2008 | RCA M4004 MP3 Player
    RCA OPAL M4001 MP3
    If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
    1. Right click on the device within the Explorer or My Computer window
    2. Select the format command (full format) to reformat the internal memory of the device.
    3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
    Dec 05, 2007 | RCA OPAL M4001 MP3 Player
    Rca Opal
    Nov 16, 2007 | RCA OPAL M4001 MP3 Player
    RCA opal
    Nov 07, 2007 | RCA OPAL M4001 MP3 Player
    319 people viewed this question
     Grubhead
    Grubhead
