Question about Kenmore Dryers
I have a Kenmore Dryer, model # 96585210 / 65852. I have it apart and have narrowed my problem to the actual motor. I get a humming noise, but the motor does not spin. After a few seconds, it stops humming altogether an smells a little. After a few minuess it does the samething. New motor? What do I check to verify?
  • Kenmore Master
  • 7,482 Answers
You have verfied the motor is shorted out already, when you hear it just hum and smell like burning rubber/electric.
Yes replace the motor.
Posted on Oct 03, 2010
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Kenmore electric dryer when i turn it on all I hear is a humming noise
 hold down the door switch with tape and try to start it while turning the drum inside. if the motor doesn't start then you might need a new motor; expensive.
if the humming noise is actually the motor running and the tub is not turning then it is the belt; inexpensive.
Jun 28, 2008 | Dryers
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Kenmore Dryer
sounds like it may be overheating.. Might try to take apart and see how much lint you got built up on the motor... may be causing overheating Is this the ONLY time it makes the humming noise when you go to start it??? May also be the early warning of bad start winding or start relay on the motor
Sep 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dryers Logo
236 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
