Question about Refrigerators
Door was ajar on my frigidaire upright deepfreeze and now it won't work
  • Refrigerators Master
  • 2,525 Answers
The air vents are iced up.you need to melt out the ice that's in the air ducts or remove the food,shut down the machine for a day and let it melt out on it's own
Posted on Oct 02, 2010
Why is door ajar alarm on when door is closed
Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
Sep 22, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Sep 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door ajar alarm keeps signaling with door shut and locked. What would cause this?
The door sensor causes that.
See to it the door really closely tight.
A dirty or defective sensor will fool the micro-controller to send an alarming.
Have it check and clean by a service technician.
Good luck.
Jun 28, 2011 | Frigidaire 21 cu. ft. / 595 liter Upright...
Door ajar beeping
Please replace your door seals with original ones. Otherwise your door will not able to close properly.
Sep 10, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW: the upright freezer was on its back for about 8 ho...
It is usually reccomended to let it stand in it's normal position for 24 hours prior to running to allow any oil to run back to the compressor. Unit should work.
May 18, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
