Question about Canon DR-9080C Path-Through Scanner
Scanner Canon DR-9080C recently started scanning at a slower speed. All setting look to be the same compared to another unit. Any thoughts?
  • 490 Answers
Do you have enough disk space? Try disk Defrag and create more space. Also check the Format you are saving, is it TIFF compressed or uncompressed? The uncompressed file size is really huge.
S. Mohan, Chennai, India
Posted on Oct 03, 2010
  • Mohan Sriraman
    Mohan Sriraman Oct 03, 2010
    If you are scanning in 24 bit color (16.7 million) the file file size will be very high. To convert such a large file, you also need a host computer with enough computing power and atleast 2GB RAM.
    S. Mohan, India
Lower reading unit broken?
Ensure you have selected Duplex option. Canon DR 9080C uses LED lights and hence the chances of failure of light source is fairly low. Try scanning in Color.
The scan module, if required, can be replaced and is available in the market between $600 to $750. Please ensure that the module is faulty before replacing. (the upper and lower modules are interchangeable, except for a few plastic parts)S. Mohan, Chennai, India
Feb 24, 2012 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
DR-9080C Extremely Slow
Change your USB port and Cable and Try. Buy a good quality USB cable, this makes some difference.If even after this the speed is (s)low, check if there is some virus on your Computer or try on a different computer.
S. Mohan, India
Jul 02, 2009 | Canon DR-9080C Path-Through Scanner
DR-9080C BackgrounfColour Dropping Out
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
Need CapturePerfect 3 driver for Canon Scanner DR 9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Jun 28, 2008 | Canon DR-9080C Path-Through Scanner
Imprinter won't work on DR-7580/9080C
May 31, 2008 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
170 people viewed this question
old marine
old marine
