Question about Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator
Water is leaking from the bottom, where can I look for the drain to unclog it? Thanks
Why is there moisture leakage from inside my cooler?
The drainage pipe is blocked or dirty. You will have to find it to unclog. Or find the water drainage container at bottom the in the drain pipe ther blow throw to unclog.
Aug 03, 2015 | Refrigerators
Where is the sunroof drain located on 2002 monte carlo ss and how do i unclog it?
Water leaks are fun to trace out. the drain holes and tubes can be seen with roof open and can be unplugged with compressed air . but usually the headliner is soaked and leaks on to seats the windshield will leak on to passenger floor. remove glove box and check for wetness along "A" pillar.
Apr 30, 2014 | 2002 Chevrolet Monte Carlo
Plugged drain
Need to completely defrost freezer. hot rags, hot water, paper towels, etc. Until you get all the ice out you don't have a chance of unclogging the drain. Could be just ice clogging it too which in that case hot water will solve that as well. If it's something else clogging the drain, I've used a mini bottle brush to unclog them or even a stiff piece of solid wire.
Mar 18, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
Water leaks into bottom of refrigerator
defrost drain was clogged , unclogged drain solved your problam
Oct 14, 2009 | Refrigerators
Frozen water in bottom of freezer
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Kenmore 62832 / 62834 / 62839 Bottom...
Water Leak at Defrost Time on Jenn-Air JCD2389G Side by Side
On the freezer side take the bottom drawer out and look at the back wall. You may get a partical view of the bottom of the cooling coils and directly below is where the water will drip from these coils. You may need a light and get your head back there to see the drain hole but it's there. This drain area could be filled with ice so, a hair dryer will do wonders. A tube with a little air pressure can unclog the drain. Pour a little water down the drain to make sure it's unclogged. Check this area often as this problem will happen again.
Dec 17, 2008 | Jenn-Air JCD2389G Side by Side...
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
Clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Oct 07, 2007 | Refrigerators
Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
