Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
How do I remove existing motor and replace it with a new one ? Hayward 2.0 hp # SP2615X20 Thank you
    Novelist:
  • 116 Answers
Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 02, 2010
My 2hp hayward super pump is just out of warranty and has begun leaking. It also has a high pitched whine which comes and goes. Does that mean waters gotten into the bearing and if so can I replace it?...
Yes, water may have entered into the motor, mainly into the front motor bearing, where it washed away the lubrication. This will only make the noise louder and will need to replace the bearing. otherwise it will eventually seize and no longer work.
Apr 23, 2014 | Hayward Super Pump 2hp, Sp2615x20
most common leaks are at the shaft seal. when they fail, it will get into the motor and wash away the lubrication from the front bearing. that in turn will create different types of noises coming from the motor. So, you will need to not only change the mechanical shaft seal, but if the noise is bothersome, then the front bearing can be changed. it will eventually seize and the whole while will get louder.
bearings are pressed onto the shaft and will need to be pulled off with a gear type puller. Then repress it back onto the shaft.
I have Hayward (A O Smith) 1.5 hp pool pump c48l2n134b3, was makeing loud noise, but today stopped working and is making sound like zzzzzzzzzzzzzzzz sound, but not pumping or working. Do i need a new...
sounds like a seized bearing. they can be replaced at your local motor shop or pool store. now that its buzzing, i would also suggest getting the start capacitor replaced at the same time.
Oct 05, 2013 | Hayward 1.5hp Pool Pump Motor Motor A O...
Leak on pump
Most common leaks on these pumps - Shaft Seal.
Replace the pump Shaft Seal.
It looks like this:
Aug 20, 2012 | Hayward Super Pump 2hp, Sp2615x20
We will be replacing a Hayward 1.5 HP motor for our pool with 120 GPM filter. Should I replace with another 1.5 HP, or would it be better to repalce with a 2.0 HP motor? Any downside? Thank you -
Actually, a pool really does not require you to up size the motor. Most pools should be plumbed with a 3/4 HP or 1 HP pool pump (though my preference is a variable speed).
A good rule of thumb for simple understanding is that you can OVER PUMP a filter, but you cannot OVER FILTER a pump. So having a larger filter is not a problem. As long as the pool is turning over 1 - 1.5 times during a run cycle, your existing pump will be just fine.
Here is something else to think about; having a larger filter and still maintaining the smaller pump from your previous filter allows the water MORE TIME to filtrate in your filter. The pressure on the filter will be reduced, causing less stress to the components of the pool system, and the water will come out cleaner, taking advantage of the filtration area of your filter.
Also, if you try to up or down size a pump without changing out the impeller or some of the more critical operating components, you would not see a major difference in performance. Also, you could cause damage to the existing pump.
Dec 08, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a NorthStar pump. The motor went out so I have it replaced with a different manufactured motor (WEG). Same HP and even a higher SF factor than the original. The new motor draws 10 amps (rated is...
THATS WHAT YA GOT 2 DO ..SOUNDS LIKE YOU HAVE THE WRONG MOTOR .9.6amps IS A 1 1/2 HP ... A 1HP IS 7.6amps.. SO A QUICK FIX WOULD TO GET A 3/4 HP IMPELLER , THAT WILL GET YOU BACK IN THE NEEDED HP RANGE .. welcome to the HAYWARD NORTHSTAR .. HEY IF'N I WAS ANY HELP COMMENT OR VOTE ..JAY
Aug 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Changing motor hayward 1.5 HP
Remove the rear motor cover and lock the shaft to spin the impeller off. Be sure to note what voltage your old motor was set for and duplicate that setting on the new motor.
We sell the motor at www.arrowmotor.net
Jun 01, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
I need to replace my pump motor.
to pull off the impellaer use a flat sloted screw driver on the back side of shaft and turn impeller off then to get bearings off use a steering wheel puller the insides should slide out after this k
THANK YOU FOR USEING FIXYA
RATE ME
May 02, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
360 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
