Question about Precor 9.31 Treadmill
Key pad unresponsive - Precor 9.31 Treadmill
Compaq nc 6220 laptop keyboard water damaged and all keys unresponsive
We have all done it .It was a cup of tea that went over my last laptop and there was no way that I could repair it. If you have insurance cover on it specifically you may be able to claim, otherwise expensive repair.
Keyboards start around 19 pounds free postage on Amazon There are wireless ones too. Hope this helps Anna
Mar 02, 2013 | HP Compaq nc6220 Notebook
The touch screen is unresponsive.
Hello!
Try calibrate the touch panel to see if it work.
- Press yellow key
- On the key pad press 1993.
- Press 5 times red key (stay pressing a bit longer on the fifth time)
Then you will see an option to calibrate your touch screen. You will need to press the point.
If this doent work you will need to change the touch panel.
Hope this helps. Good luck
Jul 21, 2011 | Gestetner DSm725 Color Copier
Mouse pad stopped working
If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
Dec 11, 2010 | Computers & Internet
My HP 15C calculator recently developed a problem with the number pad being unresponsive. Calculator appears to pass the self test, however, the key pad test does not work at all. Suggestions for repair?
If the keyboard test fails the calculator should be sent for repairs. One shop in Pennsylvania repairs most models, except the newer ones. The URL is www.fixthatcalc.com. Best of luck!
Dec 28, 2009 | HP 12c Calculator
Key pad
The touchpad itself will have to be replaced. It is a common problem nowdays. You can get parts, manual, and more at repairclinic.com or partselect..com
Nov 18, 2009 | Cell Phones
Kitchen Aid KESH307BBL9 with a F2:E5 displayed code
clean the ribbion connector off with a pencel eraser a few times and reinsert into the control, if this does not solve the issue then you nedd tor replace the touch pad, which will come with a new ribbon
Apr 12, 2008 | Kitchen Ranges
Dead control panel
No F7 or E7 in my tech sheet could it be a F1 F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad let me know thanks
Jan 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Precor 9.31 Treadmill Logo
21 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
