Question about RCA HD52W66 Projection Television
Convergence Hello, I have an RCA HD52W66 , I have seperate Colour lines and a 3D picture. I have no Convergence option. I know when I bought the TV I had this option. Please verify where this option can be found in the menu set up?
    Problem Solver:
  • 9 Answers
No menu option is a clue to your problem. No menu option for convergence is due to the Micro not seeing a active convergence module in the unit. This is a post check, when the unit is turned on, and on some units, only done at AC power up.
With that in mind, you need to check your (PW=power) pcb for the conv module. This is easy to find, but on most RCA is located on the plastic panel that is in front of the CRTs. On this model, you should see PW conv PCB on left and Conv PCB on right. Top left corner is a plug with two wires, BP611, (i think) which should have like 300v DC. If you dont have the B+ go to the Primary power supply. More then likely you will have it.
If your 300v is there, order the PW conv module. NOTE: most of these modules are rebuild only and cost about 70.00 to rebuild at PTS. Other wise, you can trouble shoot at board level.
ONLY WORK ON THIS IS YOU HAVE CAN SAFELY USE A METER, AND HAVE SOME ELECTRONICAL SKILLS. NOT FOR BEGGINERS!
Scott
JTV repair.
Posted on Jul 23, 2008
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W66 Television convergence is screwed up and gone from the set up menu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 25, 2011 | RCA HD52W66 Projection Television
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
3d rainbow pictures..with colorful waves..and no convergence menu to fix it.
You will need to replace the FL231, DL231 and CL230 you can get the parts with free instructions with pictures at the following link. The parts are all listed under the RCA parts category total cost is about 11.00 http://servicemanuals.vstore.ca/
May 14, 2009 | RCA HD61W66 61" Projection HDTV
Poor Picture on HD 52'' Projection RCA TV nearly 4 yrs old
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | RCA HD52W66 Projection Television
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
RCA HD52W66 convergence problem
you will need to replace FL231, DL231 and CL230 all located on the deflection board . You can get replacements at the following link with free instructions on how to do the repair. the parts are all listed under the RCA parts category. Heres the link http://servicemanuals.vstore.ca/
Jan 06, 2009 | RCA HD52W66 Projection Television
RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Nov 24, 2008 | RCA HD56W66 56" HDTV
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Jun 25, 2008 | RCA HD52W66 Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W66 Projection Television Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
