Question about Panasonic Palmcorder SDR-H18 Camcorder
Panasonic usb? I am borrowing a panasonic palmcorder from someone to make videos. I have recorded some, and would like to connect to my laptop via usb. I bought a package with several usb adapters, non of which fit any hole the camcorder has on it. What do I need?
    Problem Solver:
  • 5 Answers
The camera end of the cord should be a "standard" plug same as fits some/most digital still cameras and at least some cell phones.
If your camera is like my SDR-H200, you have to remove the battery and run the camera with the AC adapter, and the USB cord goes into a little trapezoid-shaped hole in the lower-rear part of where the battery was.
Bernie
Posted on Jun 29, 2008
I need free download of driver software for Panasonic PV-DV910 palmcorder for my pc with widows 7
There are none to download. Panasonic suggests the following when the computer fails to recognize the camera:
  • After re-inserting the SD card into this unit, reconnect the supplied USB cable.
  • Select another USB terminal on the PC.
  • Connect the supplied USB cable again after restarting the PC and turning the unit on.
  • Digital Palmcorder Camcorder
    Dec 17, 2015 | Panasonic Video Cameras
    Transferring Video to my Laptop
    For this purpose, you must have a USB cable that connects your palmcorder to your laptop. It must be there in its box itself.
    After connecting, please insert the CD that came with your palmcorder and install the software. If you don't have the CD, then you can download the required software from this below mentioned link:
    Panasonic Palmcorder software download
    Jan 23, 2009 | Panasonic Palmcorder PV-GS70 Mini DV...
    Panasonic vdr-m50 software cd
    Possible solution but I'm not sure. Don't know enough about video files, etc. Does someone know more? Panasonic VDR-M50 camcorder original software won't work on vista PCs. This freeware might work. Please, someone check it out:
    http://www.dvdflick.net/
    Sep 15, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
    How to download video from panasonic nv-gs15 to Computer
    first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
    CHARCOIS
    Aug 24, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
    Panasonic palmcorder
    this is either a sinc problem or you tryed copying a write protected disc.
    Jan 02, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
    Transfer to MacBook Pro from digital video camera
    when you connect the camera to your mac via firewire, make sure you have an application open that will allow you to import the material.    The most common application being 'imovie'.
    Dec 15, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
    Panasonic Palmcorder PV-GS85 Problem: Capture video with Windows Moview maker via USB
    I believe you have to use a Firewire (IEEE 1394) cable to transfer the video. From what I have read, the USB connection is only if you want to use the camcorder as a "live" camera.
    Dec 09, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
    Palmcorder
    Connect ur recorder to the computer and see what happens!!
    If it is thro' USB normally ur stills come. For dumping however u need 1394 connectivity and then ofcourse windows movie maker or studio 8 s/w. After all, computer can't survive without software.
    right?
    Nov 28, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
    "Tape Not Inserted" on Panasonic PV-DV203 palmcorder
    hai, If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
    Nov 08, 2006 | Panasonic Palmcorder PV-DV203 Mini DV...
    Panasonic Palmcorder  SDR-H18 Camcorder Logo
    110 people viewed this question
    Top Panasonic Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    zimcloud
    Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
