Cycling Logo
Posted on Oct 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adjusting lime coasting - Shimano Cycling
Anonymous
Level 3:
Genius:
  • Master 1,788 Answers
  • Posted on Oct 02, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1788
Questions
Helped
361969
Points
4093
Take it to your Trek dealer and let them do the 30 day check up on it. Your cables probably need adjusting anyway, after 30 riding days all bikes should be retightened. It should not cost you anything.
1helpful
How do I get lime out of the sewer pipe servicing a toilet?
lime will react with an acid or caustic soda( sodium hydroxide) Talk with a plumber to ensure that any heavy solvent will not harm the pipes first. May be a toilet snake used by plumbers will scrape away the lime allowing it to be flushed to t\he main syatem
Oct 09, 2014 • Home
Tranmission slips stuck in 1st gear. Goes forward in reverse
The shifter cable has stretched and needs replacing or the adjustment for it has moved and needs adjust
How do i changemy time zone form west coast to east coast?
Right click time on taskbar, select Adjust date/time and then click button Change time zone. Select your time zone from drop menu, then click ok.
1helpful
Sloppy idle,sloppy low end throttle,back firing when coasting down
Back fire on coasting down,deceleration,is a lean condition,that will also cause the idle,low end sloppy throttle,idle speed jet has become dirty,a good carb clean/rebuild with carb kit,carburators synchronized,and fuel mix adjustment,I would also check for any air leaks,that can cause a lean condition too.
2helpful
I have a Rheem EcoSense tankless water heater that I want to set the temp to 140degF. How do I set it internally for this?
1) The best place to find this information in your manual.
Typical Rheem manual in my files shows temperature is adjusted by pressing UP and DOWN temperature buttons on remote.
2) Manual says: Temperatures of up to 140°F
(60°C) for Light duty models and up to 180°F
(82°C) for Heavy Duty models can be
achieved with the MAIN (UMC-117) remote
control and a dip switch adjustment. Only
qualified service personnel should perform
this adjustment. Only factory authorized
remote control(s) should be used.
3) Typical manual shows information on page 22-23. Search pdf for 'temp'
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
4) This information squares with what I heard before that trained service technician is needed to adjust water temperature.
I think Rheem does this since tankless will not achieve that rise in temperature if incoming water is cold.
BTUs put out by tankless burner has limit.
If incoming water is colder than certain temperature, then tankless cannot raise temperature quick enough as water passes through burner.
5) You might also need a tempering tank, to modify cold water in winter:
http://waterheatertimer.org/Tempering-tank.html
6) Suggest you also read the yearly maintenance required for tankless.
For example tankless are prone to lime build up and need to be de-limed each year with vinegar.
Lime build up will certainly affect water temperature.
7) Following 2 links might be helpful for tankless owner:
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Adjust temperature higher, HOW?? Problem is reoccurring now every batch brewed.
Could be lime on thermostat probe.When unplugged remove probe and crack off lime deposits.To access ,remove top lid and loosen fill tube nut for fill basin.Take out basin and thermostat is underneath. Also check heating element or hi-limit.Ohm to check with a meter.
How do i adjust the water flow from the hot water dispenser? I need it to come out faster.
If your talking about the hot water faucet the flow rate can't be adjusted.There may be a blockage from lime at the tank fitting.You will need to clean fitting of lime.
My delta 132900 gets too hot.
With these Faucets, you can remove the handle and make adjustments to the max Hot water setting (scald guard).
You may also have a faulty or lime-covered cartridge.
SEE THIS SITE for making adjustments/replacing the cartridge.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Top Shimano Cycling Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
