Question about Harley Davidson 426290 AM/FM Radio
2009 flhtcu no sound from speakers just headset, light on speaker switch not working.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Sounds like vibration damage to the audio circuit. Verify the connection to the speaker switch. If all is good, radio will need to be repaired. Contact Iron Cross Audio (www.ironcrossaudio.com) for repair options
Posted on Oct 03, 2010
On my 2008 flhtcu my radio will be working fine then speakers will stop working [no sound]i will turn rocker switch off then on & some times the sound will come on.i think its a bad rocker switch but i'm...
Hi S.Vale, switch could be a contributing factor, take it out of the housing and inspect it for loose or broken connections also inspect the spring pressure on the toggle for adaquacy and the toggle contacts, sometimes they get contaminated by excessive grease and dirt. If no luck ride the bike over to your local dealer and strike up a friendly conversation with someone in service. Good luck
Oct 01, 2013 | 2008 Harley Davidson FLHTCU Ultra Classic...
2006 FLHTCU no sound
First off, make sure your speaker switch is in the proper position. You would be surprised how many folks come to the shop with the same problem because the switch is in the wrong position! If this isn't the problem, check to make sure the speaker connections are ok. If the radio needs repair, it will have to be sent by your dealer to United Radio. Retail cost for radio repairs is $400 if you don't have extnded warranty.
Jul 10, 2012 | Motorcycles
Radio plays but no sound. Last week or so I would be riding along and the speakers would lose sound, if I switched the radio output switch to either of the radio output to speaker select positions, it...
With the 07, you may have vibration damage to one of the main boards interlayer traces.
There are issues on those bikes that will need to be checked and the radio will need to be repaired
Contact Iron Cross Audio for options
Jul 03, 2011 | Harley Davidson 426290 AM/FM Radio
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
No sound from the speakers with my dell laptop inspiron 700m I trouble checked everything.I have the sound when I plug my headset. Is it a sound card or a driver problem? Can I download another driver?...
Fred if you get sound to your headset from the same port you get no sound for your speakers, it is the speakers and not your headset. Are there any speaker lights on at all? If not maybe your power supply for the speakers is bad.Try a different set of speakers in the same computer and see what happens. If they work, the speakers are bad. Otherwise you have some strange connection problem.
Feb 03, 2010 | Dell Inspiron 700M Notebook
Laptop speakers does not work, headset does
When you connect your headset in to the laptops 3,5 jack connection there is a little switch inside that socket.If you push in the jack it turns the pc-s speakers off.Probably that little switch is stuck,you can move around the jack to try to free the switch.No other explanation for this issue.
Jul 13, 2009 | Dell Inspiron 700M Notebook
06 ultra radio no sound from speakers only headset.
Switch is fine. You have a damaged audio circuit caused by vibration. Check the bikes mounting brackets. probably broken. The radio will need to be repaired. www.ironcrossaudio.com
Apr 21, 2009 | Harley Davidson 426290 AM/FM Radio
Usb headset
you should have a speaker icon in left of task bar, right click it> adjust audio properties> audio tab and check your mic headset is on the drop down list on the sound recording, if so click on it, then go to the sound playback and click the advanced tab and select headphones.
Next click the voice tab, check the voice playback is your headset and the voice recording is set at your headset and then click test hardware
Aug 19, 2008 | Acer Extensa 503T Notebook
Harley Davidson 426290 AM/FM Radio Logo
315 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
