Question about JVC Televison & Video
How do i get my JVC remote to get video to run in LP instead of SP when manually recording?
  • 23 Answers
Usually you can change from SP to LP by pressing the record botton again. It works with some brands & models but not all. You will need to specify the JVC model # for exact instructions.
Posted on Oct 02, 2010
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Why does my camera stop recording after one hour? i need to record 90 minutes
Your camera records in two modes: SP and LP modes. SP is a higher quality mode that runs for about 60 minutes, while LP records for 90.
To change to LP mode, open the menu and select [VCR setup]. Select [REC MODE], set it to [LP] and close the menu.
Keep in mind that your video and audio will be of noticeably lower quality with this setting applied.
Mar 08, 2011 | Canon ZR200 Mini DV Digital Camcorder
I recorded video from my Sony Handycam to the RH387H HDD and then wrote the video onto a DVD-R disc using the XP setting (instead of SP, LP.....). The disc can only playback now on the LG387H, but cannot...
make sure the disk is finalised after recording, if this does not help then the bit-rate it uses for xp may not be compatable with other dvd players, in which case stick to sp,lp or dual-layer sp is best if ou can.
Jan 25, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I need to know how to switch the tape speed from sp to the long play setting without a remote. the universal remote i have wont give me the option. it records only 2 hours on a 6 hour tape instead of 6...
Normally this setting is found on the remote if there is no parallel settings on the panel of the set.
So if youhave lost the remote controller the universal remote must be changed to one which can select the speed settings. Normally the default settings is on the SP mode while the LP mode needs to be selected.
The other option is to identify the trigger of the main processor and use a manual switch to turn on the LP mode. Check for the manual of the set and look for the LP output pin of the processor.
Here the SP mode output also must be taken into consideration so that you can use a manual 4pole two way switch to activate the SP-LP mode.
Otherwise you may need to get the original remote control from the OE maker.
Jan 03, 2011 | Televison & Video
How do I change SP setting to LP setting?
Goto manual mode> then to tape setting> change sp to lp.
I hope this helps.
Sep 05, 2010 | JVC GR-D32 Mini DV Digital Camcorder
Recording from VHS to DVD
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
-Tha Mp3 Doctor
Recording more than one VHS onto a DVD
Try pausing the dvd recorder inbetween tapes, this usually works, otherwise consult your owners manual
Jan 09, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
139 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
