Question about Philips 32PFL5403D/27 32 in. LCD TV
My Philips TV is stuck on the setup screen in which I'm instructed to press the green button on my remote. When I press or hold down the green button nothing happens.
  • 23 Answers
Check the remote batteries first. If ok try pressing the "MENU" button instead on both the remote & the TV.
Posted on Oct 02, 2010
  • omegadrag146 Oct 02, 2010
    Batteries are brand new. Menu button on both the remote and the TV do nothing, same with the input button.
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
How to setup phillips universal remote to a panasonic tv
More items...
Nov 29, 2016 | Panasonic Televison & Video
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Need rca crk17sa users guide for codes for Magnavox TV
    Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
    http://www.directv.com/DTVAPP/content/remote_codes
    Here's how to program your DIRECTV remote control:
    1. Press MENU on remote.
    2. Select "Parental, Favs and Setup"
    3. Select "System Setup"
    4. Select "Remote"
    5. Select "Program Remote"
    1. Look up the control codes for your DIRECTV remote control.
    2. Make sure your TV is turned on.
    3. Slide the mode switch at top of remote to "TV".
    4. Press and hold the MUTE button. This is located above the number 1 button.
    5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    6. Enter the first TV code you have. The green light on remote should flash twice.
    7. Aim remote at TV and press PWR button once. The TV should power off.
    8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
    1. Make sure your TV is turned on.
    2. Slide the mode switch at top of remote to "TV".
    3. Press and hold the MUTE button. This is located above the number 1 button.
    4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5. Then enter 991, the green light on remote should flash twice.
    6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    7. When the TV powers off, press and release the SELECT button.
    Mar 08, 2010 | Televison & Video
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    TV REMOTE CONTROL NOT WORKING
    1. Turn your TV on.
    2. Press tv on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press tv on your Sky remote control again.
    5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
    At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
    8. Press tv on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV.
    11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
    Oct 17, 2008 | Philips HDD065 MP3 Player
    32PFL5232D/37
    The code is 0081 and this is how you do it.
    '4 digit' or 'Brand Set' method
    1. Turn on your TV.
    2. Press TV on your Sky remote control.
    4. Press TV on your Sky remote control again.
    5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
    If the light blinks once only, re check the code for your TV and start again at step 1.
    6. Press the on/off button (power-top right button on your Sky remote control).
    If your TV switched off, press select . The light on the Sky remote control blinks twice.
    If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
    If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
    7. Press TV guide .
    If you see the TV Guide screen, the remote control setup process is complete.
    If you did not see the TV Guide, you must now set the TV Guide function as follows:
    8. Press TV on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
    Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
    Zone 2 Vol Fix
    Try this:
    FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
    Jan 19, 2008 | Yamaha RX-V657 Receiver
    Philips 32PFL5403D/27 32 in. LCD TV Logo
    891 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
