Question about Singer Sewing Machines
I don't know how to thread a twin needle on a Singer
    Genius:
  • 1,788 Answers
You can use a regular cup (paper or coffee) to put your extra spool in, then just thread as you normally do but put one thread in each needle side
Posted on Oct 02, 2010
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
2277 TRADITION
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
How i use twin needel
Although your machine does come with a second spool pin to allow two spools of thread, it does not come with a button or setting for a twin needle. You can probably put one on, but I must caution you that you can only straight stitch on it, because if you try even a narrow zigzag, its likely that one of the two needles will hit the plate and break, and they are expensive.
If you want to try it, I can tell you that you need to buy a twin needle--preferably one with the two needles close together. Put one spool in its regular pin, and the other on the extra spool pin, and thread both threads exactly the same, and at the same time. You will not be able t use a needle threader--you will have to thread them by hand.
Jun 28, 2014 | Singer 2250 Tradition
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
Fix tension on Singer 4552SW
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight--if tension is too tight back
off one number or letter at a time, if thread is too loose increase
one number or letter at a time till you get the correct stitch
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8.also check to make sure the top thread has not come off the thread
take up lever
if you don't have a manual, & want one, singer has a free pdf
manual to download
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 4552) do not put in
the sw
Click search
Jun 05, 2012 | Singer Sewing Machines
Bobbin thread too loose in singer 9805c
change the needle
make sure the thread isn't coming off the thread take up lever
clean under the needle plate & bobbin area for lint or loose threads
try a different thread
make sure the fabric & needle & thread are compatable
do you have a manual?
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9805 ) don't a the C in the box
& click search--if you don't find what you need--contact singer customer service
Mar 19, 2012 | Singer Sewing Machines
Using a twin needle for the first time - topstitch is fine but understitch is loose - i can pull the thread and stitches come out. thank you.
Is your bobbin thread actually under tension? check that it is fully into the tension spring, it sounds like its not tensioned fully.
Normally with a twin needle you'll get a little zigzag showing on the underside but the stitches should be secure.
Jul 20, 2011 | Singer Confidence 7469 Mechanical Sewing...
I need instruction and project manuals.
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=687&option=com_virtuemart&Itemid=54
Jul 22, 2010 | Singer Curvy 8770 Electronic Sewing...
Twin needle treading for singer sewing machine 3116
Yes, put your second thread in a cup behind your machine and thread your machine like normal
Jan 22, 2010 | Singer 3116 Simple
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
