Whirlpool clothes whsr wfw8300sw02 code F-20 ?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It means that the washer is not detecting entrance of water or pressure switch trip is not detected. Please press pause/cancel button twice to clear the error code. Let the unit drain and unlocking the door. Now switch it off and let it without power for about ten minutes and replace all the cables and switch it on. If still the issue is not resolved and there is no water in it then you'll need to check that the inlet valves are not kinked or plugged. If there is water in it then you'll need to check the drain pump and inlet valve operation. Also check that the pressure switch hose is properly connected and check the wire harness connections to Central Control Unit, inlet valve, drain pump and pressure switch. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 02, 2010
What is the rated capacity for a Whirlpool Duet Sport Washing Model WFW8300SW02 Type 831
Capacity = 3.3 Cu Ft
Whirlpoolcorp.com download manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8300SW0&siteCd=WHRCOM&userType=Consumer#
The breakdown for Whirlpool Serial Numbers is:
1st Alpha Character = Manufacturing Division Code.
2nd Alpha Character = Year Manufactured (See Tables).
1st and 2nd Digit = Week of Year Manufactured.
3rd though 7th Digit = Order of Manufacturing that Week.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
If this was helpful, please rate post
Sep 13, 2014 | Whirlpool duet Washing Machines
I have a duet sport WFW8300SW02 which I am having
Here is the code meaning
F26 is for door lock - do you hear the door lock one time or with click sound repeatedly.
F20 no water entering - do you check water coming into washer
F21 long drain-do you take a look of pump filter
Another possibility is the pressure switch was bad.
Hope you can figure out the issue.
Oct 19, 2013 | Whirlpool duet Washing Machines
Front door bellow on model wfw8300sw02 replacement
do you need the part number for the door bellow or what do you need
Oct 27, 2012 | Whirlpool Front Tub Seal Bellow 8181850
Whirlpool Duet Sport Washer (model: wfw8300sw02) partially drains. Clothes spin out as dry as ever, but 2-4 cups of water are always left in the filter/pump. I've 1) emptied the filter 2) disconnected...
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Jun 07, 2011 | Whirlpool Washing Machines
Whirlpool washer wfw8300sw02 code F21 what does that mean
the F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
c...
Feb 03, 2011 | Whirlpool Washing Machines
Bellow ##W10111435 whirlpool washer WFW8300SW02.
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport HELP!!!
Remove and clean your drain pump.
Check the pump motor impellers.
If you have water in there, have a shop vac close by.
Mar 10, 2009 | Whirlpool WFW9400S
F1 code for duet sport
you have a bad machine controller, check the warranty in your use and care guide to see if the part is covered under manufacturer warranty.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
