Question about Hardware & Accessories
Clear instructions for power plus 24 hour timer. What is meant by slices ?
I can't identify 'power plus' timer specifically.
I'm going to guess at answer based on other manuals.
Your timer has a dial on it's face. You rotate dial to set time of day. And the time of day lines up with a triangle marker usually located on center part of dial on right side.
The dial has 48 plastic pieces around outer edge of dial, and each one of these 'slices' or pieces of plastic represent 1/2 hour.
So the dial has 48 'slices' around the dial, and each 'slice' can be lifted up to set timer on-off functions. Sometimes they lift up and out instead of straight up.
Usually when slice is up, timer is ON, and when slice is down, timer is OFF.
Posted on Oct 03, 2010
How do I set a 24 hour timer D809/1
HPM 24 hour timer instructions: rotate dial clockwise until current time lines up with pointer located on inner dial. There are segments located around edge of dial. Pull up these segments to set on-off times. Turn Load switch ON. Plug Load into timer. Plug timer into receptacle. Manually rotate dial clockwise and observe Load turning ON-OFF. This will show if timer is ON or OFF when segments are pulled up.
I think the D809/1 has 15 minute intervals. The only manual on the HPM site for a 24 hour timer close to this is:
https://hpm.com.au/app/document/asset/23/16/6/d8180d-hpm-24hr-outdoor-timer-instruction-sheet.pdf
Sold at Bunnings in Australia, you might find a manual with one! Alternatively, here is another place they are sold and given they are inexpensive, it might be worth it to just get the instructions. Amazingly, if you try to search for a manual for this, you can not find it. You just get comments like the techs were not help, the manual was in Chinese, and after translation, were not even understood by the techs. Heaven knows what the truth is. The HPM manual above is clearly in English. Note the device manual above likely is set for half hour intervals. Good luck.
http://www.radioparts.com.au/ProductDisplay.aspx?popup=1&Category=SXKK1045&Product=49161200&ProdDesc=D809%2F1+24+HOUR+ANALOGUE+TIMER+HPM
Aug 11, 2017 | Hardware & Accessories
I have a new Tork 1102 timer 240V. It works dial rotates clicks on and off but loses four hours in a 24 hour period what is wrong.
The timer motor is syncronous and meant to run on 208-277 Volt, 60 cycles per second. It appears that you have 50 cycle current running it, which would result in a 4 hour loss in every 24 hour period. There is no adjustment for this.
Sep 13, 2016 | TORK Hardware & Accessories
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Westek Indoor 1 Outlet Digital Timer TEO2DHB instructions
Question is unclear:
Do you want instruction manual, or want somebody to read the instruction manual and explain it?
1) Open following link for instruction manual:
http://waterheatertimer.org/pdf/TE02DHB-manual.pdf
2) For explanation of instructions:
-add a comment and ask specific question saying what part of instruction is confusing. For example 12 hour or 24 hour format is letting you choose 12 hour am-pm format or 24-hour 'military time' format where hours of the day and night are numbered 1 through 24.
-and you can also take advantage of fixya live support, and expert can speak with you over phone while you program timer.
Sep 25, 2011 | Hardware & Accessories
I have the first alert timer model et220 and i have no instruction with it. could you provide me with instructions on setting the timer?
Question does not describe the timer.
Web search for et220 does not show image of timer for clear identification.
My files do not show et220
Question posted under 24-hour analog timer.
1) Open following link for possible instructions:
http://www.fixya.com/support/t1329823-first_alert_timer_et220
2) Add a comment with clear description of timer for possible identification and instruction manual.
3) Post a photo of the timer on Flickr. Add a comment with link to photo for possible identification and instruction manual.
4) Maybe possible to e-mail the company for instructions: orders@vwimc.com
Sep 08, 2011 | First Alert 24 Hour Timers - 2 For The...
I forgot how to set it ,
Timer is not identified.
Add a comment with clear description of timer for possible help.
If you have analog dial-type timer, open following link for instructions:
http://waterheatertimer.org/How-to-set-timers.html
Jul 07, 2011 | First Alert 24 Hour Timers - 2 For The...
HOW TO RESET TIME
6124 is 24-hour timer single-pole timer
Open following link for images, instruction manual, ez set instructions, and wiring instructions
http://waterheatertimer.org/Leviton-timers.html
Apr 18, 2011 | Leviton 6124H 24 Hour LCD Programmable...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
Hardware & Accessories Logo
577 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
