Question about Casablanca Fan 3245T Ceiling
Fan turned on by phantom signal
At random times day or night Casablanca ceiling fan gets turned on at random speed
  • 3 Answers
Have had similar problem for years when main power supply is interrupted for even a few minutes (lightening storm, brief outage of some sort). When the power supply returns, the fan starts up at the highest speed - not great when you aren't at home. (Mine is in an older kitchen with old time gas pilot lights in the range.) I replaced the wallswitch control - but I still turn off the main power switch when I know I won't be at home
Posted on Jun 28, 2008
If you have more than one fan and they have remote controls they may be set to the same frequency. You can re set one fan to operate at a different frequency. The instructions ar in the manual or online.
Posted on Jun 06, 2008
  • Fanboy Jun 06, 2008
    One other possibility is that Casablanca fans have a security setting which is designed to do exactly that - turn the fan on and off randomly so it looks like someone is home to a potential burglar. You may have switched that on by accident. Its on the remote or control panel.
How do you operate a inteli-touch casablanca ceiling fan
i looked everywhere,casablanca doesnt have anything but a picture,but,i eventually found this for you,dont break it,there are no parts being made http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ReplaceElectronicsIT.pdf
May 28, 2015 | Casablanca Fan CAS 66668T Panama II...
I have a Casablanca ceiling/fan light with one wall switch. The fan will only work on high speed and makes a shrill type of noise. The light has worked but not consistently. I was wondering if I have a...
is the switch made to turn on and change the speed, the switch is acting up should chang the switch, but if you change the speed with the chains the wiring is loose up in the fan just need to take it down and tighten up the connections,good luck.
Aug 08, 2011 | Casablanca Fan 3245T Ceiling
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Jul 20, 2010 | Casablanca Fan (3232A) Ceiling
Casablanca Delta II fan wobbles terribly at high speed. How can this be fixed?
Use the fan regulator to adjust the speed of the fan, and if it does not adjust the speed, then you have to replace the fan regulator.
Good luck...
May 31, 2010 | Casablanca Fan 3245T Ceiling
Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
Ceiling fan light flecker
Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Casablanca Fan 3245T Ceiling Logo
306 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
