Tefal Ultimate EZ Clean Pro Deep Fryer Logo
Posted on Oct 02, 2010
Can not get my oil to drain - Tefal Ultimate EZ Clean Pro Deep Fryer
How to change oil in lowrider
New motorcycle engine oil (as per manufacturer's recommendation)
Oil filter
Wrench or socket set
Oil drain pan
Funnel
Shop rags or towels
Prepare the Motorcycle:
Ensure the motorcycle is on a level surface and turned off.
Allow the engine to cool down if it has been running.
Locate Drain Plug and Oil Filter:
Identify the oil drain plug underneath the motorcycle engine. It might be covered by a skid plate or other protective cover.
Find the oil filter. It's usually located on the side of the engine.
Drain the Old Oil:
Place the oil drain pan underneath the drain plug.
Use a wrench to carefully loosen the drain plug (anticlockwise). Let the old oil drain completely into the pan.
Once drained, re-tighten the drain plug securely.
Replace the Oil Filter:
Use an appropriate tool to remove the old oil filter. Be ready for some additional oil to drain out.
Apply a thin layer of new oil to the rubber gasket on the new oil filter.
Install the new oil filter and tighten it according to the manufacturer's instructions.
Refill with New Oil:
Locate the oil filler cap, usually on the side of the motorcycle's engine.
Use a funnel to pour the recommended amount of new motorcycle engine oil into the oil tank.
Check Oil Level:
Nov 27, 2023 • Motorcycles
What is the right oil and filter to use on the range2007 hse?
How To Change Oil and Oil Filter on Range Rover Sport or Land Rover LR3
  • Place an oil drain pan below the oil filter and drain plug and unscrew the oil filter.
  • Lubricate the rubber seal with clean oil and install the new filter. Tighten to 13 foot-pound torque.
  • Remove drain plug in the oil pan and drain the oil. Catch the oil in the drain pan. After draining the oil install and tighten the drain plug to 18 foot-pound torque.
  • Fill engine with 5W-30 weight oil. The 4.4 V8 takes 8 quarts; the 4.0 V6 takes 6 quarts. Start engine and check for leaks.
  • Recheck level and top up as necessary.
  • Reinstall the under engine shields / skid plates.
The oil doesn't drain out of my 2001 Harley Davidson Dyna When I remove the oil plug only a half quart of oil drains out. Dipstick is removed and oil is hot.
Are you sure you're pulling the correct drain plug?
On Harleys with the oil tank under the engine, there are usually two drain plugs, oil and transmission drains.
Also, some have a drain on the bottom of the engine, which only a little residual oil will come out of it.
Finally, when the oil stops draining from wherever you're draining from, does the oil dipstick show that the oil level has dropped?
If not, you got the wrong plug!
2helpful
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
7helpful
3answers
2002 FATBOY, AFTER SITTING A WEEK, CHANGED OIL AND FILTER,VERY LITTLE OIL CAME OUT, ASSUMED ENG. OIL LEVEL WAS LOW, BUT NO OIL LEAKS DETECTED. ADDED 3 QTS , ROAD BIKE ABOUT 20 MILES. NOW ENG. IS LEAKING...
The Oil Capacity is 3.5 qts. (3.3 L) are you sure you pulled the right drain plug, and drained the ENGINE oil? The engine oil drain hex bolt is located on the right side of the motorcycle and is removed/installed horizontally.
Transmission oil drain hex bolt is located on the left side of the motorcycle and is removed/installed vertically.
3helpful
3answers
I added oil to my Cadillac and it drained onto the ground
Before adding any more oil, make sure that you have securly replaced and tightened the oil drain plug (which is located on your engine's oil pan, under your car).
The FixYa Team!
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
2answers
2000 ES 300: how to change oil?...
drain via sump plug,replace oil filter,fill through oil filler cap.
11helpful
4answers
Were do you drain the oil on a 1340 evo motor
Evo's drain from the oil tank, not the engine
3helpful
2answers
How do you change the oil filter on a Hyundai Accent 1998/99?
Replace the oil filter after draining the old oil, and" BEFORE "adding new fresh oil, otherwise you'll be dump all that fresh oil, on the ground,while you "TRY to get the new filter installed.
Step 1 Remove drain plug,Drain oil into drain pan
Step 2 Remove oil filter
Step 3 Reinstall drain plug,qnce oil has drained.
Step 4 Fill new filter with oil,lube seal on filter.
Step 5 Install new filter, Add fresh oil to proper level.replace filler cap
Step 6 Run engine check for leaks.
Happy motoring!
Top Tefal Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Kardoc
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
