Question about Frigidaire ATF6000ES Front Load Washer
Hi, I have a Frigidaire Gallery, 16 Cycle, Heavy duty Washer. I've had it for apprx. 7 years. It is starting to make a loud banging noise on the last rise cycle. I read something on Frigidaire Washers about a spider, something to do with the drum. I'd be so thankful if you could help me figure out the problem.
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
Posted on Apr 12, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
SOURCE: Frigidaire Gallery Heavy Duty Front Loading Washer, FWT445GESI
If you access the bottom panel you can see the shocks mounted from the base of the machine to the tub. you will need to take the top panel off and you can see the springs the are mounted about 1/2 way in at the top and connect to the to off the tub
Posted on Nov 02, 2008
aborcass
  • 2651 Answers
SOURCE: A loud bang .....like a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Posted on Feb 14, 2009
  • 26 Answers
SOURCE: Belt came off washer
Spider arm to the washer drum is broken. Parts is expensive and labor to repairs will cost you more than if you just go out and buy a new washer. Sorry for the bad news.
Posted on May 25, 2009
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drum makes loud noise when spinning
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
142 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
