Question about Canon DR-9080C Path-Through Scanner
When i Scanning my Documents with following setting 200 DPI, Duplex mode and Gray Scale with this setting, i have very slow my scanner speed, about 15 ppm speed on 9080c scanner, pl solve this problem if any solution found
  • 490 Answers
Please run disk-defrag and create more space in the hard disk.
S. Mohan
Posted on Oct 03, 2010
Slow save on pdf file with capture perfect3
Change the scan resolution to 200 dots per inch (200 dpi). If 300 it tajes a few seconds. If 1200 dpi, it may take really long.
Jul 29, 2014 | Canon DR-9080C Path-Through Scanner
We are having HP Officejet J4580 all in one in our office. but the problem is that even if i scan a document in gray scale & PDF then also the file size come out to very Huge; Which troubles us alot...
Scanning in gray scale alone will not bring down the scannned documents size alone. In your scan settings there should be a setting whereby you lower your DPI (dots per inch) or scan resolution. The standard DPI is usually about 300. Try lowering it to about 100 and check the scanned document size again. Lower your DPI until you reach the appropriate document size for emailing etc.
Best wishes,
Graemevm
Jul 26, 2011 | HP OfficeJet J4580 All-In-One Laser...
My laser mfp 1815dn is reducing the size of the image of the document i am scanning. how do i get it back to scan and save a full page?
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
Documents:
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Dell Printers:Dell MFP Laser Printer...
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
S. Mohan, Chennai, India
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
How do I scan photos
Although different scanner has different option still I am giving you the general method of scanning.
Put the photo on the scanner (photo face down touching the glass of the scanner) - look the cover is perfectly placed and no light is entering inside of the scanner. Now run the scanner software - select scan item as "Photo" (other options are text or documents etc), select the option "Color" (other option is Black and white or gray ). Select the resolution more than 200 dpi (more dpi will give better output), give path where the file will be saved after scanning or keep it default, choose the file type JPEG is better (other options may be BMP, TIF etc). First you get preview - look the expected scan output - if required you adjust or lace the photo on the scanner better way - then again get preview - if you are satisfied you may select the portion out of the whole preview page for scanning - now click scan. It will give JPEG file in the specified location.
Jun 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
HP Photosmart C3135 is slow scanning documents
You can speed up process by choosing a low quality of scanning. Decrease the DPI ( Dot Per Inch -parameter) to 100 dpi or 200 dpi
Mar 07, 2009 | HP Photosmart C3135 All-In-One InkJet...
Scanning in colour
Who and where do you get the idea that you should be able to, to scan in colour you need a colour scanner, yours is not it has a greyscale scanner only.
This machine has a scanning kit option but that is not colour see specs below.
AR-NS2 Network Scanning Kit (optional) 4
Type:
Flat bed monochrome scanning system
Original Feed System: Platen/document feeder, simplex/duplex with RSPF feeds up to 39 opm
Resolution:
200 dpi, 300 dpi, 600 dpi
Image Format:
TIFF 6.0, ITU-T G3/G4 TIFF, G3/G4 single/multi-page PDF
Scan Destinations:
E-mail, Desktop, FTP, URL
Destination Profiles:
Up to 200
Operating System:
Windows 95/98/ME, 2000, XP
Network Protocols:
TCP/IP (includes SMTP, LDAP, FTP)
Network Security:
E-mail server user authentication
Software:
Sharpdesk Document Management Software (included)
Link to brochere of the AR-M 237 GREYSCALE copier
Jan 10, 2008 | Sharp AR-M237 Copier
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
203 people viewed this question
old marine
old marine
