The dell 1907fpvt monitor how do you get the back off to work on it
  • 13,433 Answers
Remove all the screws from the display, remove the stand, check for hidden screws under labels, soft objects etc.
After that the casing is only held in place with plastic clips, insert a plastic stick, case opening tool, flat screw driver or your fingernails in the cracks in the plastic, or openings, and move it up and down. The clips start opening, you need to go around the display, etc until you get it apart, then it will again have screws on top of the power supply and mainboard cover etc. very simple from there on.
Here is a quick video of a guy taking apart his monitor, i don't recommend the exact method of "hammering" the screen open, but you see where the display cover opens up.
Posted on Oct 02, 2010
On My 1907FPVt Dell monitors the green power light button flashed for awhile and know they display no colar and the screens will the monitor will not power up. I have two monitor and they both have failed...
Inspect the boards for bad caps with domed tops, very common failure in all brands of monitors.
See examples here: http://s807.photobucket.com/albums/yy352/budm/DELL/
Replacement boards: http://www.lcdrepair.us/Invpowersupply.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Dell UltraSharp 1907FP 19 inch LCD Monitor
Have 21 inch monitor dell st2210,mi problem is everythink desapere from the screen and later come back,lock picture is in the center of the monitor al the time i have 1 year waranty i call dell speak to...
Connect the monitor to some different computer, e.g., a laptop, to verify that the monitor is working.
If not, take it back to DELL/STAPLES, and get them to check it out, or to exercise the "warranty" to get it repaired/replaced.
May 14, 2010 | Dell ST2210 21" Monitor
Resolution wont resize properly
Try resetting your monitor to the factory settings. If that doesnt work I suggest you unistall your monitor in device manager Only if you have the monitor cd. If you do not have a cd to your monitor you can always download on the internet. These two options should help you but if they dont go ahead and come back and repost your question.
Jul 13, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Dell latitude D610 and 1901 FP monitor
Did you hold down the Fn key and press the function key for the external VGA port? It should cycle as LCD only, LCD and VGA, VGA only and then back to LCD.
Dec 28, 2008 | Dell Latitude D610 Notebook
Dell monitor problem
Try pressing Fn + F8 keys to toggle the screen image.
Nov 30, 2008 | Dell E176FP 17" LCD Monitor
I am using a Dell Lattitude D830. I added another monitor (Dell) for home use. First time I hooked it up, it worked fine. Today, I took the laptop with me, so unplugged the monitor. Now, I cannot get the...
Have you tried the "function key + F8 key" since that usually is the key combo you press to switch between built in LCD and external monitor on a Dell laptop.
Worst case scenario would probably be some type of driver setting or resolution setting might be to high. and in that case you can try system restore (with the monitor connected of course) to the day it was working and see if the setting go back to that time...
This solution is the easiest one to try since you can always undo the restore operation if it doesn’t resolve the issue
19 in Dell flat panel monitor
also need to see video how to remove back of monitor case
May 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell dimension monitor not working flashing on when unplugged and plugged back in
hi Fshumway, time to change your monitor, it is a problem on this kind of monitor, it is 20" ? or somekind of energy problems, or in the cable conector in , to your computer, is bad. If you have other monitor, use it, and see if work fine.
hope this help!
Carl
Nov 05, 2007 | Dell Dimension 4700 PC Desktop
Digital video stopped working
did you try to set the out put on the monitor to dvi on the display settings? in windows
Jan 05, 2007 | Dell UltraSharp 1907FP 19" LCD Monitor
Computers & Internet Logo
256 people viewed this question
David Payne
David Payne
