Question about Honda Karcher G2400HH-R Pressure Washer
I can't get the nozzle to lock in the pressure washer. The part doesn't slip back over the ball bearings. What am I doing wrong?
    Scholar:
  • 100 Answers
More than likely you aren't doing anything wrong, try putting some grease on the o-ring inside of the quick connect socket and push the nozzle and wand against the ground and slide the brass ring down. If this still doesn't work I would recommend replacing the quick connect socket with a new one.
Posted on Oct 25, 2010
Karcher vario lance not working on high pressure
Sounds like the ball bearings in the vario nozzle are not in the proper position.
https://www.youtube.com/watch?v=3U6irpNnhfw vario repair
Oct 12, 2014 | Garden
How to get my siphon hose connection to work?
First of all the siphon hose to suck you need to create a low pressure for the venturi to work, this is achived by changing the nozzle on the end of your lance to the "soap" nozzle it should be the black nozzle in your case, or the one with the biggest hole.
With this in it should suck thru the clear chem tube, if not there is a little ball bearing and spring under the brass barb that the clear tube pushes onto that may be gunked up, if so it will not allow the chem to pass it. you will need to remove the ball and spring and clean it up with some steel wool and reassemble (Take note of how it comes apart) and you should be back in business.
Hope this helps.
Brad
Aug 15, 2014 | Karcher 2500 PSI Pressure Washer
Why won't It siphon soap?
These units use a venturi to inject soap, where the tube goes onto the brass barb, that should unscrew and there is a little ball bearing and spring in there that sometimes stick when thay have not been used for a little while, if you clean the ball bearing up with some steel wool and lube it up and reassemble, 9 times out of 10 this will rectify your problem
Hope this helps,
Brad
Jul 29, 2014 | Dewalt DPH3100 Gas Pressure Washer
My pressure washer will not mix with detergent
First you need to see if you have to utilize a soap nozzle normally black in color and with a large orifice that should create low pressure and or a selective change over nozzle with a spray pattern of 65 degrees.If so then you may have a clogged port where the chemical line connects to pump inside there is a check valve with a ball bearing that may be stuck from previous use without rinsing,free the ball by letting water flow with no trigger gun connected just water coming out of hose engine off and insert a nail or pin long enough to push the ball that is in the barb carefully til you hear ******* good luck.
Sep 15, 2011 | Briggs & Stratton Briggs Stratton 1800...
Have a troy bilt 220 lb Briggs Stratton Put the clear tube into the gallon of soap, but will not draw. Also, how do I remove the nozzle to attach the low pressure nozzle to apply soap solution?
It won't draw soap unless you have the low pressure nozzle on. It can be replaced by pulling back on the slip collar then pulling out the nozzle. The new nozzle is then put in by again pulling back the slip collar and sliding the new nozzle in, making sure the collar goes all the way back and locks into place.
Jun 19, 2011 | Garden
G-3050 - area to draw soap - how to put washer/ball and spring
First off you must be using the low pressure nozzle for the chemical injector to work. It will not work on high pressure. The spring goes into the injector body first with the ball in metering valve.
Apr 17, 2010 | Karcher 2500 PSI Pressure Washer
It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher dirtblaster does not oscerlate the water.
Stripped down the head of the dirt blaster by unscrewing the shaft from the end nozzle(it was quite tight). Removed the white disc from the nozzle using pliers and then cleaned out the 4 holes in the disc. Under the disc is an assembly which houses a ball bearing. I noticed that the ball bearing did not protude beyond the recess which houses it. I PUT TWO SMALL FIBRE WASHERS IN THE RECESS THEN REPLACED THE BALL BEARING. THEN REPLACED THE WHITE DICSC. Noting that the ball bearing protrude by approx 1/16th of an inch.
Re-assembled and the dirt blaster now works perfectly
Feb 20, 2009 | Garden
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Honda Karcher G2400HH-R Pressure Washer Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
