Question about GE JKP75 Electric Double Oven
How do i set the glass touch reference point ?
I've got a rattan Outsunny cube patio set. My glass on the table shattered in the hot weather and I've been trying to get in touch with Outsunny to complain about it. Can you help me please.
Armoured glass is used for table tops, oven tops etc. To get the glass to break/shatter, it requires temperatures exceeding 200 degrees Centigrade and then cooled quickly in one spot or something has been dropped on it.
Jul 12, 2017 | Ovens
Outer glass on oven door shattered, can i still use it
I wouldn't use it the temperature will get very high and the glass that is on the inside will be extreemely hot and could burn somebody badly if touched, Also the glass gets everywhere as they explode and if not completed cleared out may cut.
Nov 04, 2010 | Ovens
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Ovens
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
RBS305PDS Broken Glass on Oven Door
inner door glass part number 4449259.. youll need to remoe the door from the unit and lay it on the table, thats the hardest part, theres a few different ways the door releases, so refer to your manual if available, then its just a matter of removing the screws form the door until you get to the broken panel, might thake a little time but as long as your patient no need to call service man. probly save $150
Nov 23, 2008 | Whirlpool RBS305PDS Electric Single Oven
GE JKP75 Electric Double Oven Logo
114 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
