Question about LaRoche Brothers Teddy Bear
Hi, the harness on our maxi cosi tobi seat has completely jammed and I can't pull the straps out at all. Does anyone know how I can fix this?
Is the maxi cosi combatible with a dodge grand caracvan
Hi Lisa
Please contact Maxi-Cosi customer care team USA & Canada for assistance - 380c2c95-927b-443b-80ce-6a556ec98186.jpg
Feb 09, 2014 | Maxi-Cosi Maxi Cosi Mico Infant Car Seat...
Need new straps for maxi cosi tobi
Hi Mandy
Due to the safety implications of a carseat harness being incorrectly fitted we are unable to supply a harness to you as a spare part item.
To replace the harness the carseat would need to come in for our engineers to provide replacement and safety checks to ensure product is working as per specification. 1924a6a3-e420-4f10-b6df-f9a1deebe867.jpg
Apr 05, 2013 | Maxi-Cosi Priori
Can you re thread straps on maxi cosi tobi?
Hi
Due to the safety implications of this being incorrectly done it should not be attempted at home. The carseat needs to come in for our engineers to re-thread the harness and ensure it is performing as it should be.
Please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide further assistance.
Apr 05, 2013 | Maxi-Cosi Tobi Car Seat - Jet Black
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Hi, i cannot get my maxi cosi to recline. can you offer any help with ideas?
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Aug 11, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Straps on my maxi cosi tobi car seat is stuck, can't loosen it
Hi, This sounds like either the harness is twisted at the back or inside, or there is a build up of dirt etc that could have fallen through the **** strap area. I would suggest that you go to this link and contact the supplier who will be able to clarify this for you. http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en I hope this helps.
Nov 11, 2009 | Baby Gear
We have a maxi cosi tobi car seat. Our 20 month old daughter is able to get her arms out of the straps even tho they are pulled tight enough for the green indicator to come on. We would like to know how...
If the carseat harness indicator is green, you are right there is not a great deal else that you can do. There is one product, made by Sunshine Kids that may help, or perhaps you can find something similar, see the link below:
http://www.happybabystore.com/Travel-Safety/Sunshine-Kids-LOCK-TITE-High-Performance-Harness-Clip-p4500.html
It may also be worth getting the Tobi checked out just in case there is a fault with the harness.
I hope this helps.
Aug 31, 2009 | Maxi-Cosi Baby Gear
LaRoche Brothers Teddy Bear Logo
191 people viewed this question
Top LaRoche Brothers Baby Gear Experts
Dorel UK
Dorel UK
Are you a LaRoche Brothers Baby Gear Expert? Answer questions, earn points and help others
