Question about Singer Sewing Machines
I CANNOT THREAD THE BOBBIN. I BELIEVE THAT I HAVE TAKEN THE CORRECT STEPS. I LOOSENED THE KNOB ON THE RIGHT. THE NEEDLE DOES NOT MOVE. WHEN I PRESS THE FOOT PEDAL, THE MACHINE STARTS RUNNING. THE LARGE WHEEL ON THE RIGHT IS SPINNING. BUT MY BOBBIN THREAD IS NOT BEING SPOOLED. I DONT GET IT? PLEASE HELP! (IT WORKED THE LAST TIME I HAD TO SPOOL THE BOBBIN THREAD.)
    Genius:
  • 1,788 Answers
Make sure that you have it wound around the thread guide the correct way, or else you have no tension, and that your bobbin pushed against the bobbin winder. Study your manual, and if you need one with bigger print go to www.singerco.com and download one for free, then adjust your text size. Good luck
Posted on Oct 02, 2010
How to tighten or adjust wheel socan sew after threading bobbin
your wheel should tighten enough to make the needle, bobbin, etc to operate. if you loosen the knob the needle, etc shouldn't move. to adjust keep pressure on the knob counterclockwise and loosen the screw. at a point the knob will slide over a hump. you may now tighten the screw and try to use the bobbin wind and sew functons. you may need to do this adjustment a couple of times.
Nov 09, 2014 | Sewing Machines
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
On a Singer Quantum 9940, the upper thread will not 'catch' the bobbin thread. What should I try to do?
Make sure that your needle is all the way up. With many needle clamps, loosening it enough to remove a needle is not enough to insert one -- you have to loosen it a little bit more. You can determine that by looking right above the clamp on the shaft -- there is what looks like a grey bar and the end of the needle should be right under it. If your needle is too low, it will not catch the thread.
May 24, 2014 | Singer Quantum 9940 Computerized Sewing...
Needle does not move when I try to sew.
On these old singers, there is a locking washer that controls the tighten and release mechanism. If it is not in the proper place your efforts to tighten and loosen to engage the sewing functions do nothing.
Aug 11, 2012 | Sewing Machines
My machine is new and worked briefly but now . . . . the machine is threaded correctly and the bobbin is placed correctly. When turning the knob for the initial pick up of the bobbin thread, it does not...
You have described your problem just fine. Have you just changed the needle in your machine? If so, check it is in the right way, you want the flat shank to the back.
The needle has a scarf (scoop out) at the back - if it is facing to the front then the rotary hook (bit that goes around the bobbin and catches the top thread) can't catch the needle thread behind the needle.
Also check needle is fully up into the housing, this could also cause problem.
I'd suggest that you visit www.sewingabout.com and check out the pages on general sewing machine use, care and threading up, lots of helpful pictures and information which may be of assistance to you.
If it isn't your needle backwards (very easy to get wrong, happens all the time), then the timing could be out, which isn't so easy, but as its new I'd be very suprised if this was the fault. Just check needle, make sure top and bottom threads are threaded correctly and have another go. Also, remember to turn flywheel towards you.
Jul 14, 2011 | Singer 7444 Mechanical Sewing Machine
Needle not going up and down but power getting to the machine
Check your manual for the bobbin winding steps for your particular model.
On some machines there is a knob in the center of the hand wheel that is loosened for bobbin winding - this also disengages the movement of the needle. Tighten for sewing.
There may be an additional step, such as moving the bobbin winding pin to the right or the bobbin winding wheel to the left.
Apr 06, 2010 | Bernina Sewing Machines
Knob not moving
Check the bobbin winding feature to see if it is disengaged.
If there is thread jammed in the bobbin area, the wheel will not move.
Turn off the machine and remove the needle and presser foot.
Remove the bobbin. Open the needle plate and remove the bobbin case and clean the area from lint and thread that may have accumulated there.
Feb 24, 2010 | Brother Sewing Machines
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
